Results 1 to 28 of 28
Like Tree43Likes
  • 6 Post By simonsk8r
  • 1 Post By woodhouse
  • 1 Post By Dimal
  • 2 Post By 338
  • 2 Post By flynnaus
  • 2 Post By 338
  • 1 Post By 338
  • 1 Post By simonsk8r
  • 1 Post By Dimal
  • 4 Post By 338
  • 1 Post By Caffeinator
  • 2 Post By 338
  • 3 Post By Yelta
  • 4 Post By Caffeinator
  • 5 Post By Caps
  • 4 Post By Dimal
  • 2 Post By Yelta
Thread: Ultimate Guide to Aeropress article
    Oct 2009
    Geelong
    1,123
    Heya guys, am reading an interesting article, thought I'd pass it on for those who use Aeropress. It's a big write up haha, but very informative! Even covers stuff like for those who never really have gotten a decent brew out the Aeropress, and tips to help with that. Lots of helpful hints, recipes, the history of it etc...
    Enjoy!
    https://coffeechronicler.com/ultimat...the-aeropress/
    Dimal, flynnaus, Otago and 3 others like this.
    Oct 2009
    Geelong
    1,123
    Wowza, this method in the article is utterly fascinating... never even thought to do that. Worth an experiment! Have pasted it below:
    THE AUBADE METHOD
    https://youtu.be/Kh5ldPdxbQA
    I recently encountered this brilliant technique which doesn’t really have a name yet.
    As far as I can tell, it was first invented and popularized by Eldric Stuart of the now-defunct*Aubade Coffee*in Vancouver, so maybe we should call it the ‘Aubade’ method?
    The same approach has since been used to win at least a couple of Aeropress competitions.
    This brewing style is unlike any other recipe out there.
    The idea is that you do several extractions, and then mix them afterward to create the perfect cup.
    The first extraction creates what Eldric Stuart calls ‘sour acids.’ The idea is that all the most potent, citric flavors are pulled out in this first extraction.
    After that, you remove your plunger, add water, and proceed to brew a second time. This time you add more water. This creates the bulk of the brew. Then you adjust the taste by adding the sour acids from the first extraction. Spoon by spoon. Like if you were to season a tasty stew.
    The result should be the most balanced Aero-Joe you can imagine.
    Eldric Stuart is also the guy behind the Aesir Aeropress filters (which I highly recommend). For the best results, you should use his filters.
    I have tried this method several times, and have been blown away by the flavor clarity.
    At first glance, it seems a bit weird and counterintuitive, but when you think about it, a guy like Tetsu Kasuya espouses some of the same principles in his 4/6 method. Sweetness and acidity are extracted at different times in the brew cycle and make it sense to balance them perfectly.
    Try this recipe below, or check out the video above, where the Canadian coffee-YouTuber*Brodie Vissers*shares his modified recipe, which also works like a charm.
    Normal position, use Aesir filter for the cleanest result
    21.5g coffee
    Add 60g water at 94°C/201°F
    20s plunge (without hiss) and set sour acids aside
    Add 140g water at 94°C/201°F
    Skim the scum off with a spoon
    Plunge 1:45 to 2:45, no hiss
    Add around 30g water at 70°C/158°F*
    Add ~11g sour acids, to taste
    Senior Member woodhouse's Avatar
    Dec 2016
    362
    that is just taking the piss.
    Dimal likes this.
    Oct 2009
    Geelong
    1,123
    Quote Originally Posted by woodhouse View Post
    Hahaha! I know, seems like fuffing about, but still intriguing hey . Give it a go!
    17,114
    Nah... I'll stick with the simple straight forward methods and recipes. Still makes great coffee.
    simonsk8r likes this.
    338
    338 is offline
    Mar 2017
    891
    Interesting article Simon and a great summary of the Aeropress world championships results and techniques . Interesting reading to get so much info on one place.
    Somewhat loses his credibility with his link to 'best espresso machines' - https://coffeechronicler.com/gear/espresso-machines/ - spoiler alert, Breville feature heavily and money is no object choice is Breville Oracle. Interesting choice for a 'coffee professional'!
    Dimal and simonsk8r like this.
    Senior Member Erimus's Avatar
    Mar 2014
    Kippa-Ring Qld
    387
    It's basically a informercial by people trying to oust the ever popular French Press.
    Me, I find the 'Aeropress' to be a very overrated piece of equipment.
    Sep 2012
    Hobart TAS
    296
    Quote Originally Posted by Erimus View Post
    Me, I find it a very overrated piece of equipment.
    The Aeropress or the Oracle?
    May 2008
    4,126
    Or you haven't learned to use it properly. Some of the best coffees I've ever had were from the Ap.
    Have a good read of the article.
    338
    338 is offline
    Mar 2017
    891
    Hard to overate the Aeropress at it's modest price. I think it is great for travelling, my first choice.
    artman and Dimal like this.
    Mar 2014
    Kippa-Ring Qld
    387
    The French Press is great for traveling too and makes better coffee...
    Each to their own though.
    338
    338 is offline
    Mar 2017
    891
    Like the french press also, just the glass doesn't get on too well with baggage handlers
    Dimal likes this.
    Oct 2015
    173
    Ermm, not sure if you are trying to bait people but French Press is in no way better than Aeropress flavour or extraction wise. The filtration is not as fine/effective and results in muddy fines which effect the coffee flavour. Not saying you can't make super tasty coffee from a French Press.
    Probably why there isn't a French Press world championship.
    Oct 2009
    Geelong
    1,123
    Quote Originally Posted by 338 View Post
    Yeah I thought it was an exceptional article, covered a lot of different aspects, ways to brew, what each variable is etc.
    Yes very weird about that haha, dunno what that's about, but the article I hope stands on it's own merit hey . He a licensed Q grader too, unless his recommendation was for people at home with limited funds.. dunno I'd have to read the article. Or he's a Breville rep, meh hehe
    338 likes this.
    Oct 2009
    Geelong
    1,123
    Hehe.. not everything is a conspiracy or plot to undermine other brewing methods. I'm not saying Aeropress is the greatest thing on earth, but yeah some of my best ever coffees I've had have been through Aeropress too. Of course to each their own!
    But it's nice to talk about things that produce nice coffee .
    Dimal likes this.
    338
    338 is offline
    Mar 2017
    891
    Quote Originally Posted by simonsk8r View Post
    I think he is probably on a commission from Amazon, I am assuming that is how he makes his money.
    17,114
    Exactly...
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    7,049
    I suspect this may well be the case.
    These people abound on social media nowadays, we even have our own resident influencer who relentlessly promotes a number of espresso related products, if its not one of the brands he favours it's simply no good.
    338
    338 is offline
    Mar 2017
    891
    Still a lot less than the relentless Mr Bean! 'Hi my names X, and I sell that model' I was going through my PMs a few days back and read a few emails from one of his banned alter egos. Amusing reading, the altered ego had PMed me after I commented on a machine , suggesting I should purchase from Mr Bean who had really looked after them. Said I wasn't in the market, but anyway was 5km from the importer in Sydney who I had already dealt with. Altered ego then suggested Mr Bean would give the best price and do wondrous things. Seemed weird at the time, now knowing it was Mr Bean himself makes sense. Now how would I describe that behaviour......
    Dimal, simonsk8r, Yelta and 1 others like this.
    Jun 2009
    Moonta SA.
    7,049
    Have to say, he added a bit of colour to the place, it's all a little subdued now.
    For some reason I was on his favoured persons list at one stage as well, he used to pepper me with PM's asking advice.
    I imagine interesting times will come again.
    Jul 2017
    296
    But, but he's got one squillion 5 star reviews- for jugs, group seals and all manner of meaningless stuff. I call BS on much of that .
    For mine, he only ever subtracted rather than added. Given more opportunity, he probably would have driven us all away.
    I think they call it dissociative identity disorder?
    https://www.youtube.com/watch?v=plZRe1kPWZw
    Dimal likes this.
    Jun 2009
    Moonta SA.
    7,049
    Quote Originally Posted by Caffeinator View Post
    Yes! he certainly was a very naughty boy, and no! he was most certainly was not the messiah.
    Guess he added something, most of the older hands know exactly who we're talking about.
  23. #23
    338
    338 is offline
    Mar 2017
    891
    Yelta if he PMed you for advice I am surprised he didn't become the most successful Bezzara retailer in Australian history!
  24. #24
    Jun 2009
    Moonta SA.
    7,049
    Yep, guilty, I am somewhat biased.
    Dimal, 338 and Caffeinator like this.
  25. #25
    Jul 2017
    296
    Good thing he didn't sell the Vario.... Just sayin'
    Dimal, Yelta, Caps and 1 others like this.
  26. #26
    Nov 2013
    121
    I really miss TC....
    Dimal, simonsk8r, DaveD and 2 others like this.
  27. #27
    17,114
    Quote Originally Posted by Caps View Post
    Ah, he still pops in now and again...
    simonsk8r, Yelta, DaveD and 1 others like this.
  28. #28
    Jun 2009
    Moonta SA.
    7,049
    So I've heard.
