Results 1 to 4 of 4
Thread: latest silvia or prev. model
    Dec 2008
    25
    Hi this is my first post on here. Im thinking about buying a silvia, but I wanted to know if overall the newest model thats been released is better than the previous one. I remember reading somewhere that they did make some important changes with the new model, but I dont remember what they were. However, having the boiler and heating element as separate components seems like a strong advantage to me on the older model. What do people here think? Thanks for the help!
    Jan 2007
    541
    Re: latest silvia or prev. model
    idolwolf
    Welcome
    I havent tried a newer Silvia so take these comments acccordingly.
    IIRC the changes in latest silvia [2007/2008-ish] are mainly cosmetic: Different style drip tray and Chromed plastic group surround.
    I have also read that the brew thermostat was changed from 110C to 100C but have not confirmed this for myself [could also be US models only or something like that]
    If this is the case, I dont imagine it would cause significant changes in the cup on the proviso you would pull the shot at a different point in the cycle.
    I thought that the combined boiler+heating element changes were made in an earlier incarnation to the latest model.
    In mine [2004/5] they are seperatable, so the change would lie somewhere between that and the latest model.
    Therefore, the advantage you mention is somewhat offset by having to source and buy a relatively used machine [>2+ years] and of course, unless it comes from a fellow snobber you wont really know/trust its history.
    In anycase:
    If you use the machine properly: ie prime the boiler following steaming, dont leave it on in steam cycle for long periods of time, tighten the steamvalve at the beginning of each session and descale in accordance with your water quality ...... you should NEVER have element issues.
    If $$$ are not your main driver, then the most significant advantage is the support + backup gained by purchasing a new machine from a reputable dealer [ie site sponsor] .
    Jul 2007
    539
    Quote Originally Posted by reubster link=1228770915/0#1 date=1228788067
    Youre forgetting about the most important change - the adjustable OPV. This makes it much easier to adjust the brew pressure, which you will probably want to do because the Silvia comes shipped with the pressure set somewhat higher than ideal.
    Nov 2008
    362
    Silvias post-2007 can also accept pod filters, although I have no idea who seels them or if theyre any good, and Im not intending to find out either. Just something more to think about I suppose :D
  1. Replies: 32
    Last Post: 21st September 2010, 08:01 AM
  2. 2006 model Silvia
    By Leedrick in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 17th February 2009, 12:12 AM
  3. Old or New model Silvia
    By cremakid in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 19th February 2008, 01:00 PM
  4. Replies: 4
    Last Post: 23rd January 2008, 11:19 AM
