Results 1 to 6 of 6
Thread: How often to change the water in a Gaggia Classic
    Feb 2008
    62
    I was just wondering what the popular opinion is re changing the water in the container in the Gaggia Classic. I use filtered water but even after a week it starts to look not so nice. Changing more often than that seems a bit of a hassle?
    Apr 2008
    Brisbane
    5,113
    Re: How often to change the water in a Gaggia Clas
    Fresh is best
    Feb 2008
    62
    Yes, but how fresh is *fresh*....every day :-/
    Apr 2008
    Brisbane
    5,113
    Depends on the capacity of your tank
    If it is a small amount every other day would be OK
    I would go through a tank full on average every 1.5 - 2 days and I have a 4 lt tank
    Lots of hot drinks & clean flushing in that routine :)
    Mar 2008
    194
    Drink more coffee!!! :D
    those tanks arent that big :D I used to go through a tank every 2 days on my classic.
    Jun 2006
    61
    Well I have a KA Pro Line that utilizes a 2 liter tank. I use maybe 1 liter a day and top it off daily with fresh cold water. I do like to remove the tank every few weeks and scrub it because no matter how clean your water is there will be some buildup over time. Not only will you have better coffee, but the pump and plumbing will be cleaner as well..... Later!
  1. Gaggia classic water tank
    By Allison in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 11th October 2012, 07:24 AM
  2. Gaggia Classic - No steam, just hot water.
    By Degrees in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 10th July 2012, 11:16 AM
  3. Gaggia Classic not pumping water
    By geek in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 14th August 2009, 02:42 PM
  4. Gaggia Classic - Dispensing Water
    By Huhness in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 7th January 2009, 09:28 AM
  5. Gaggia Classic hot water function
    By trumboli in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 17th December 2007, 10:37 AM
