Results 1 to 8 of 8
Thread: Gaggia Classic - Dispensing Water
    Jun 2008
    46
    When I dispense water from my steam wand with the knob turned to full ON I still get water from the grouphead. This was a replacement for my Baby Dose which has the same internals and I never had this problem.
    This has been happening since new, I just thought it was a quirk but it is very annoying because water dribbles from the wand and blasts out the grouphead! I dont want to use the water from the grouphead because it is not always clean.
    Is this normal for a Classic if not im asking for a refund and getting a Silvia.
    My $30 carezza at work doesnt even do this!! >:(
    Jun 2008
    46
    Re: Gaggia Classic - Dispensing Water
    This is normal? No one owns a Gaggia Classic?
    May 2008
    4,126
    I havent own a Classic but have owned a Baby and no, it didnt leak water from the grouphead when dispensing hot water. What you are descirbing is almost certainly a fault and ounds like it could be a valve problem.
    Doubt if you will get a refund if youve already been using it for a while
    Jun 2008
    46
    Well this was a replacement for a Baby Dose which went in for repairs (Steam wand is only held in by a plastic clip and came out and wouldnt go back in) and after 3 weeks of it not coming back the importer replaced it with the classic I wanted.
    I have had problems with the importers products before and they should be looking after me after all one of their BBQs grill plates blew up in my face not just once but the replacement they sent blew up also! Shame I didnt know GAGGIA is another one of the brands they import.
    Mar 2007
    73
    Hmmmmmm....
    You got a machine which you know nothing about ..ie history wise.
    Im thinking you should replace your steam and brew thermostat.
    Very very easy to do..cost is like 10-15 dollars. Simple replacement.
    I cant say for sure but ive done that in the past to make sure i was
    working with non-faulty parts in that area.
    You can get those parts easy. If you need help ill take pictures for you
    showing how to do it.
    I assume you have descaled the machine. You never know but something
    funky could be going on. Make sure you backflush and clean out your
    Solenoid valve as well. It doesnt make sense that water would come out
    the group while opening your steam valve to full. This is why im saying to
    replace those two parts. WHo knows it could be that or not...
    This might also be some odd wiring setup. I can take pics of my internal
    wiring and you can look at yours and see if it matches up...ie colours etc.
    Try and descale and backflush first. Then do thermostat replacements.
    May 2008
    4,126
    Quote Originally Posted by Huhness link=1231218026/0#3 date=1231243145
    This was a brand new machine, correct?
    If so, demand a replacement in an unopened carton. If not, it sounds like they have replaced one dodgy product with another. You can try to get your money back (good luck) but if not, cut your losses and give them the flick.
    Let the suppliers know they will no longer have your business. In these troubled economic times, I think you might get their attention. If they dont care, then good riddance. Based on what you described about your experience with them, I wouldnt waste any more of my time and money on them.
    Try the fixes that pravspresso suggests but I recommend taking it to one of the CS sponsors if you dont feel confident with playing with the Gaggia innards
    Mar 2006
    188
    Quote Originally Posted by Huhness link=1231218026/0#0 date=1231218026
    Sounds like either the 3-way valve is faulty (or clogged), or the solenoid that positions the valve is defective. *The 3-way valve should only permit flow through the grouphead when the brew switch is flipped. *Yours sounds like it is not closing completely.
    On a Silvia, it is relatively easy to disassemble for checking and cleaning the valve. *Probably the Classic is similar, but I dont have any direct experience.
    Jim
    Jun 2008
    46
    This machine is Brand spanking new. And did this from day 1. Ill just take it back and try get a refund. Thanks for letting me know this is not normal.
  1. Gaggia classic water tank
    By Allison in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 11th October 2012, 07:24 AM
  2. Gaggia Classic - No steam, just hot water.
    By Degrees in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 10th July 2012, 11:16 AM
  3. Gaggia Classic not pumping water
    By geek in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 14th August 2009, 02:42 PM
  4. How often to change the water in a Gaggia Classic
    By kevviek in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 17th December 2008, 06:29 AM
