Results 1 to 28 of 28
Thread: Cleaning a Sunbeam 6910
    May 2007
    442
    When I backflush my grouphead, should I use a cleaning powder or a tablet? Does it make any difference? I usually backflush with a powder (Clean Machine) once a month. The first few times I used too much and choked the machine. Now I use about half a teaspoonful. How does anyone else clean their 6910?
    I cant seem to find an answer, but this may have been covered before.
    Cheers!
    Andy.
    Senior Member Coffee2Di4's Avatar
    Sep 2008
    Ipswich, QLD
    1,472
    Re: Cleaning a Sunbeam 6910
    Hi Andy
    I use the Cleaning Tablets from Sunbeam - purchased at the Sunbeam Service Centre but they cost about $18.00 for a packet of 6 tablets.
    Di
    Ali
    Ali is offline
    Apr 2008
    91
    I backflush just with water regularly and about once every few months use the Sunbeam tablets - I was advised to do so if the machine was still in warranty. Apparently there are other tablets which are cheaper which fit too
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 466B6E070 link=1231682730/2#2 date=1231714987
    I backflush just with water regularly and about once every few months use the Sunbeam tablets - I was advised to do so if the machine was still in warranty. *Apparently there are other tablets which are cheaper which fit too
    Regardless of Warranty - Failure to clean will cause problems for the product / your enjoyment and equipment reliability.
    May 2007
    442
    Thanks for the replies. Does anyone else use a powder, or are the tablets the best for the 6910?
    I should add that I backflush with water after every use.
    Sep 2008
    58
    I use a Sunbeam tablet once a week.
    Although I consider myself scrupulously clean and flush the grouphead after every shot, I only had to see what was released after a tablet backflush cycle once to be a convert to weekly tablet use.
    I continue to use the Sunbeam tablets as I cannot get a definite answer as to whether any other brands are suitable.
    Senior Member Stan's Avatar
    Dec 2007
    Just North of Brisbane
    945
    I use the sunbeam products even though they are a little hard to find where I live. When I do find them I buy a couple of packets so I wont run out. I think until someone can definitely say a product works for the sunbeam without damaging it, I will stick to the sunbeam product.
    May 2007
    442
    Thanks all. The consensus seems to be for the tablets.
    Ali
    Ali is offline
    Apr 2008
    91
    Quote Originally Posted by 406F6664734C606F6066646C646F75010 link=1231682730/3#3 date=1231717794
    To explain what I meant - was told at a dept store when I was looking for the tablets was that other tablets will fit the machine (and are cheaper), but if its still under warranty then you should use the sunbeam tablets so that you dont void your warranty.
    At the Sunbeam course they pretty much instructed us to backflush with water every day if used heavily. If used lightly, they said not to leave it for more than a week.
    Member peteru's Avatar
    Aug 2008
    78
    Quote Originally Posted by 486560090 link=1231682730/8#8 date=1231817796
    As a general piece of advice, I would suggest ignoring sales people in department stores. It is very rare to find anyone with even half a clue in such places.
    Now, for the more specific advice. If the third party tablets work the same as the Sunbeam tablets then warranty makes no difference. If, on the other hand, a repairer could tell from the condition of the machine that you have used something else than the Sunbeam product, then it is fairly obvious that the product was not a suitable replacement.
    Whichever way you slice it, if you want to be sure, use the Sunbeam product.
    DONT USE
    Jan 2008
    432
    leaving the sunbeam for a few months between backflush will cost you money
    At the Sunbeam course they pretty much instructed us to backflush with water every day if used heavily. *If used lightly, they said not to leave it for more than a week.
    the less reguarly the machine is used, then more cleaning needs to be done
    once the coffee oils go hard, normal backflushing will not remove them
    all home machine manufacturers state that you can only use thier designated cleaning products
    did a job last week on a sunbeam 6910 6mths old,
    2 coffees per day
    rinses after every use
    previous coffee suplier told him to backflush with liquid bleach once a month
    had very clean old coffee residue
    cost him $ to have blockages removed
    You do need to be careful as to cleaning products you use
    some are just dishwashing powder sold as coffee cleaner
    dishwashing powder has low suds
    coffee cleaner needs to suds up, as it is the suds/ detergent residue clinging to the walls that does the cleaning, not the wateryliquid being pushed straight through
    graham
    A_M
    A_M is offline
    Mar 2006
    6,381
    Back flush with liquid bleach... :o
    Hope it was MEDICAL / Food grade grade ;D ;D
    I am sure the Health and TGA authorities would be impressed...
    I wonder how much rinsing he had to do before getting a good shot afterwards..
    FIX... You must have some great Customer stories to tell ::)
    Problem is that many try to do the right thing BUT get told crap from friends and some of the people pushing the product or the machine..
    Ali
    Ali is offline
    Apr 2008
    91
    Quote Originally Posted by 3936275F0 link=1231682730/10#10 date=1232238131
    [leaving the sunbeam for a few months between backflush will cost you money
    What AM said ubout getting told crap... its so true. The sunbeam manual doesnt even talk about backflushing... they only mention it in the course. All the sunbeam manual tells you to do is cycle water through the group head after each use and clean the rim. They recommend to clean the group head with a cleaning tablet once every 3 months!
    Aug 2008
    78
    Quote Originally Posted by 1D323B392E113D323D3B39313932285C0 link=1231682730/11#11 date=1232443125
    Back flush with liquid bleach... *:o
    I would not put bleach or any other corrosive in a metal machine, but unscented bleach is commonly used to sanitise plastic and glass utensils when brewing. Unscented household bleach diluted at a rate of 250ml to 20l of cold water - soak for a few minutes, then rinse under cold running water. Of course, the bleach will not clean anything, it just kills any bacteria, yeast or mould. If there is a risk of residual bleach odour (or if your water has been treated with chloramine) you can rinse with sodium metabisulphate solution, which will also sanitise.
    Of course, all those chemicals should be handled at room temperature in well ventilated areas. Putting them into a coffee machine where they get heated up and come into contact with various metals is just plain stupid. However, plain old unscented bleach is fine for food grade sanitisation when used correctly.
    Sep 2007
    Northlandia
    1,363
    Quote Originally Posted by 4E697C731D0 link=1231682730/6#6 date=1231747103
    *I think until someone can definitely say a product works for the sunbeam without damaging it, I will stick to the sunbeam product. *
    I use Cafetto and it doesnt appear to be doing any harm.
    Edit - looks as though some script that automatically puts in a link when a sponsors name appears is playing up...
    Dec 2008
    45
    I use Cafetto too. I noticed some slight staining on the stainless steel backing (behind where the cup sits on the drip tray) after water escaped out the back of the group head during the backflush. Seems to have polished straight out and looks to be doing the job.
    Is it safe to pass a bit of this through the steam wand too or should it just be soaked with water?
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 11150A1B031616620 link=1231682730/15#15 date=1232577344
    I use Cafetto too.
    SB do not recommend and warn not to run the Steam when doing their recommended descale and their Tabs.
    From what I can tell this is due to the fact that there is NO way to get the steam wand to run HOT water... IT steams and thus causes some chemical changes etc... Risk management... Users might not flush and blame some one for the crappy taste etc...
    I do run cleaner through my Steam wand, but not that often..
    1: Set the steam temp to the lowest temp
    2: Steam pump to fastest = Wettest setting
    3: Lots of shorts bursts and a cool rag around the steam wand.
    And do it in an open AREA... If you do it in the kitchen it will / can leave a strong chemical smell..
    Then you have to spend some time flushing with clean water....
    After all that, you then have to reset the Steam temp and wetness.
    NOTE: The use of filtered water etc should mean that this is not required too often.
    Dec 2008
    45
    Excellent, Im satisfied with that answer as I was asking because Id done it, not because I wanted to do it.
    I dont feel like a bad boy for doing something I shouldnt have ;-)
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 23273829312424500 link=1231682730/17#17 date=1232628820
    You mean you got carried away and just turned on the steam when doing a de scale... Without reading the SB manual ???
    Naughty boy.... A spanking for you.... CS people would never do such a thing ::)
    Opps... How did I find out what to do and what not to do ..... :-[
    Dec 2008
    45
    Well I have 2 factors working against me, I work in IT and Im a bloke. Major influences on not reading the manual but instead, lets give it a try and see what it does. Seemed like a good idea at the time!
    I must pay more attention to the manual - I didnt change the steam temp or wettness but I promise I will next time. Promise... ;D
    A_M
    A_M is offline
    Mar 2006
    6,381
    IT appears to be a common factor.... *:D
    As my wife has said to me many times as well as others, including techs who have arrived at home to do work... Cable *etc...
    RTFM....
    I hope to have a pic or two up shortly... To quickly demonstrate a way to manually flush the Steam thermoblock on the EM6910...
    See my post * [here] * * *
    Site Sponsor
    Mar 2008
    13
    HI There,
    Just stumbled across this discussion - thought i would throw in my 10cents worth
    on the issue backflushing....the key principle of backflushing & cleaning groups/handles is to remove the residual coffee oils,related dirts and grounds(stating the obvious) :P
    whilst regular/daily flushing with fresh water does keep most of this at bay, a backflush...mmmm say weekly, fortnightly or so(depending on use) *will break down the coffee oils and gumming ...keeping your espresso uncontaminated by stale coffee residue.
    There are several brands of powders and tablets of varying strength & quality on the market...... it doesnt matter if its a tablet or powder(thats just personal preference) - if it is designed for espresso equipment then the principle of cleaning coffee residue is the same.
    We have seen a number of manufacturers challenge the use of other cleaners in their machines.....and to date it hasnt got past fair trading..(ie they cant enforce voiding your warranty)....just as you can use any dishwashing detergent in a dishwasher...
    There appears to be a few smoke and mirrors used to create an illusion on some products BUT in general if it is a product designed for coffee equipment *- it will(generally) clean if used correctly...
    in regards to descaling and cleaning steam arms ...i could go on & on & on......
    cheers
    Mr Bombora *
  23. #23
    Jan 2009
    5
    Hi, does someone mind explaining what a backflush is and how its done?
    I see from reading this thread that I will need to do it and its not mentioned in the manual.
  24. #24
    May 2007
    442
    Assuming you have an EM6910, the instructions are on pages 30 and 31 of the manual.
  25. #25
    Jan 2009
    5
    ok cool, so the cleaning group head instructions are what is called a backflush
    Should this be done only with a cleaning tablet? is it helpfull to do them without a tablet?
  26. #26
    10,496
    It will be helpful without the tablet.
    But you neednt go through the whole 10 minute cycle.
    Just insert the blanking plug and fit the handle loosley.
    Hit the manual button and let the basket fill to overflowing and jiggle the handle to flush any loose grounds from the shower screen and group head.
    I do this after each coffee making session.
    A full cleaning cycle can then be done with the tablet to the frequency recommended by Sunbeam.
  27. #27
    Jan 2008
    42
    Quote Originally Posted by 333E33342325510 link=1231682730/24#24 date=1235341787
    Yeah, theres the full 10min cleaning cycle that the manual suggests.......or you can prepare the machine like you would for the full flush cycle just without a cleaning tablet, press the manual button and when you hear the machine go "silent" for lack of a better word, hit the button again to stop the water and it will flush back through the machine and into the drip tray.
    Do this three or four times and should shift any left over grounds and stuff. Sunbeam suggested you do this after each session at the course.
  28. #28
    Feb 2009
    8
    Quote Originally Posted by 2827364E0 link=1231682730/10#10 date=1232238131
    I have leave it for few months! The pressure of the hot water n group head are extremely low now! Is it blocked by the coffee oil or wy else?
    I have tried the scale cleaning process, but the water outflow was too slow, so seems not really worked.. :-/
    wt can I do mates?
  1. Which cleaning tablets for Sunbeam 6910?
    By Occam in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 10th November 2010, 10:53 AM
  2. Cleaning 6910
    By RobertC in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 7th June 2010, 02:42 PM
  3. EM 6910 Cleaning problem
    By has_bean in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 1st November 2009, 06:28 PM
