Results 1 to 5 of 5
Thread: sticky Silvia steam valve
    Apr 2008
    55
    Ive had my Silvia now for about 8 months and mostly it works pretty well. One problem though: the steam valve is a bit sticky to the extent that at first I didnt realise how far it could open. Is this a flaw, or something that will wear in, in time? I expected it to be a smooth screw thread like action, not something that feels a bit like taking a bent screw out of sticky plastic.
    Mar 2006
    703
    Re: sticky Silvia steam valve
    My Silvia is quite a bit older than yours, and the steam valve is relatively free but does squeak a bit, and will leak a bit if not re-tensioned when cold. And the squeak could be quite annoying if you let it....
    Is the stickyness the same when cold as it is when hot?
    I havent had the steam valve apart on mine so not sure where it could get sticky, but there will be someone else on here that will have a better idea.
    Bullitt
    May 2007
    Perth, Western Australia
    3,163
    My ex-Silvia was similar worked fine but was always a bit tight from new. Last week I replaced the o-rings and washer, this improved performance and the valve had plenty of play at the front end again. Its an easy task to replace, a bit fiddly with my stumpy fingers but manageable. I always needed to tighten valve in morning after last use as contraction and cooling leaves it open a little and it dribbled as it heated up.
    Apr 2008
    55
    Quote Originally Posted by 45726B6B6E7373070 link=1231849448/1#1 date=1231880685
    Bullitt
    Pretty much the same at all times. It feels like a dodgy screw thread. Open it a few turns. Smooth. Continue turning. Rough. Continue turning. Smooth.
    It also sometimes leaks a bit on first getting the temperature up after being off but not consistently enough to be sure its not just that I didnt tighten it off enough after switching off.
    DONT USE
    Jan 2008
    432
    the valve needs a service in all cases
    food grade high temp grease
    or return under warranty for the supplier to fix
  1. Silvia steam valve issue maybe?
    By Sarg in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 10th November 2011, 02:39 PM
  2. Sticky La Cimbali Anti-Vacuum Valve
    By GCM58 in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 27th September 2011, 08:18 PM
  3. Does the Silvia steam valve need lubrication?
    By Arv in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 17th January 2011, 10:03 AM
  4. Squeaky Silvia steam valve
    By LastMile in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 29th September 2008, 07:23 AM
