Results 1 to 10 of 10
Thread: The unacheivable firm puck?
    Jan 2009
    14
    hi all,
    i currently have a Bodum Granos that i was given to replace my old Solis and have been unable to achieve a nice firm puck after extraction. distribution in the basket is not an issue as my dosing is fairly even and constant. the grind i use in the machine pours a single 30mm shot in 30sec (+/- 1sec). what could be the main reasons for this is happening? is this just a characteristic of this machine or am i doing something wrong?
    May 2008
    4,125
    Re: The unacheivable firm puck?
    How do your shots taste. If they taste great then dont worry about a soft puck.
    You could try a slightly coarser grind and see if a 20 - 25 sec shot improves your quality ( and puck).
    If your shots taste sour then it might be a brew temperature problem as I was experiencing with my VBM. Not sure if this can be adjusted on your machine but you can try to measure the temp. Theres one method involving a foam cup with thermometer poked through the side and then held against the group head while dispensing hot water through it. Another method involves using a DMM with the thermocouple placed in basket, dosed then locked into group head. Apparently this doesnt damage the thermocouple. There is a thread somewhere on CS about this.
    Oct 2007
    13
    Hi I had same problem with my machine. I went to clean the brewing filter from the brewing head. It was badly blocked whiched caused an uneaven water spread it pays to cheack this filter. Hope it helps. :)
    Oct 2007
    793
    does your machine have a 3 way valve? if it doesnt, then dont worry bout your pucks. you aint gonna get a nice firm one.
    if you do have a 3 way, then try higher and higher doses with clightly coarser coffee and see what that does. also, try tamping with less pressure.
    aaron
    Member peteru's Avatar
    Aug 2008
    78
    I get floppy pucks if I do not use enough coffee. Increasing the dose should help.
    Jan 2009
    14
    hey all
    thanks for the input but i have since replaced my bodum with a Brugnetti simon and the difference is incredible. rate the Brugnetti big time.
    CE
    Apr 2007
    1,687
    Doesnt that Bodum have those crappy pressurised baskets? Thats probably it.
    Jan 2009
    14
    yeh it does, thats why i promptly binned it after a couple of weeks. it was given to me so no loss. haha
    CE
    17,098
    I wouldnt have "binned it" mate.... :o
    Maybe it didnt produce great coffee but sure is a great looking machine; and sooo shiny. Would look cool sitting up on a shelf near the bar 8-)
    Jan 2009
    14
    hey mal,
    dont worry mate didnt literally "bin it", its gone to a new home!
    CE
  1. Barista / Cafe Attendant - Law Firm
    By Thundergod in forum General Coffee Related...
    Last Post: 8th April 2007, 04:53 PM
  2. Water on top of firm Silvia puck
    By ihug007 in forum Brewing Equipment (non-machine specific)
    Last Post: 6th September 2005, 11:02 PM
