Results 1 to 5 of 5
Thread: My Oscar
    Feb 2009
    1
    My Oscar
    I just bought a used Nuevo Simonelli Oscar, and cant pull good shots....thin, weak, barely hot and noooooo crema. The guy that I bought it from claims that I am not using the right grind.....I have been using a Cuisanart grinder that I bought brand new....any thoughts out there?
    May 2004
    439
    Re: My Oscar
    Can you give the model of the Cusinart grinder?
    Also, how long does it take for your shots to extract (time taken for 60ml from a double basket from turning on the brew switch)?
    Site Sponsor
    Aug 2006
    929
    Re: My Oscar
    Go back to your basics.
    1. how old is the coffee?
    2. Is your machine on for for than 20mim (with the handle in the group head)
    3. Start timing your shots 30ml in 30 sec in singles.
    regards
    Renzo
    May 2008
    4,127
    Re: My Oscar
    Apart from what Renzo suggests and they are certainly starting points, the Cuisinart grinder is not going to produce the best results for espresso grinding.
    You need a better grinder than the Cuisinart, but in the meantime, try different grinds starting with the finest and observing point 3 of Renzos suggestions.
    I would suggest a home barista course to help you get the best from your machine and, while you there, you might get to try a better grinder to see if that improves your shots.
    Another thing is what condition the used Oscar is in. It may need a good clean. Id be chatting with one of the site sponsors and investing a few $s to get your machine checked.
    Dec 2008
    7
    Re: My Oscar
    I have had an Oscar for about three months. Thin and weak shots could be explained by:
    the grind being too coarse
    not adequately tamping
    the amount of coffee you use ( underfilling defintely results in the shot you describe).
    Barely hot is a bit unusual. I give a very short cooling flush ( about 50ml) if its been turned on for a while), and barely that between shots if making a few. When i started with mine I used stale supermarket beans. Its not possible to draw crema out of those. I got a Kompac K3 touch grinder. The machine is definitely capable of a near perfect shot with decent beans and the right grind. All of the comments made by others are valid, so unless you have a faulty machine, it probably is one of the variables mentioned. p.s. its worth persevering with, the Oscars a good home machine.
  1. Where to buy an Oscar in SG
    By ferrari451 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 27th January 2013, 10:15 PM
  2. An Oscar question
    By tonym1 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 24th June 2011, 10:22 PM
  3. EM6910 to Oscar?
    By Senator in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 30th October 2009, 01:02 PM
  4. oscar down again!
    By raphec in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 17th December 2008, 07:35 PM
