Results 1 to 10 of 10
Thread: Sunbeam EM6910 flashing problem
    Feb 2009
    8
    HI guys, I hv purchased the machine one n a half yrs. It was a very nice espresso machine, but after I stored it for few months. The pressure of the it has some problem. It is not flashing, juz like leaking .... has anyone had this problem b4?? Im so dispress now...wt can I do now??
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: Sunbeam EM6910 flashing problem
    1: Was it stored with Water in it ?
    2: Where is it leaking ?
    3: Where are you located ?
    4: What type of water did you have in it previously
    Feb 2009
    8
    Quote Originally Posted by 0E21282A3D022E212E282A222A213B4F0 link=1235370947/1#1 date=1235374461
    Hi mate,
    1. No, it was not stored with water.
    2. "Leaking" is not meaning the machine has anywhere leaking, I mean the water which come out from the shower-head is very very low! It is not flashing water.
    3. Im in Syd.
    4. I used pure water.
    Now the water outflow of my machine is only ~50ml of the whole period of the manual. But the steam is very powerful!
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 4263636E62294B070 link=1235370947/2#2 date=1235377872
    3. Im in Syd.
    1: How powerfully is the Hot Water option ? This is the same pump as for the Group head...
    Depending on how it is... I can point to where the problem might / could be...
    2: I would do a full de scale cleaning process, including removal of the shower screen etc and flush the Group Head a few times etc...
    Then compare the Hot water flow to teh Group head again..
    If teh Hot water is fine, then pointing to a blockage in the head some where..
    If the same and low... Then in the main pump and or the common path...
    Feb 2009
    8
    [/QUOTE]
    1: *How powerfully is the Hot Water *option ? *This is the same pump as for the Group head...
    Depending on how it is... I can *point to where the problem might / could be...
    2: *I would do a full de scale cleaning process, including removal of the shower screen etc and flush the Group Head a few times etc...
    [/QUOTE]
    thx for your quick reply mate!!
    It is the same low pressure mate, so I think it should be the pump problem.......
    I hv tried the scale cleaning process, but the water outflow was extremely slow! Juz ~50ml per one times.
    remove shower screen? ru meaning the shower head?
    Thank you very much again!
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 6647474A460D6F230 link=1235370947/4#4 date=1235380881
    Not ya mate just yet..... * :-?
    1: The pump forces water through the main block, then via a loop into the Hot Water valve and then to the Group Head OR Hot Water, if the valve is selected.
    Thus it could still be a blockage in the main head and if never flushed fully... Then scale or crud could still be in the common pathway..
    2: Not yet to see a pump fail... But could be a first..
    My money is on a blockage... * *Only way to clear is to;
    A: Persist with flushing and good wquality cleaner and let soak for 10 to 15 min between flushes.
    B: *Or reverse the flow and manually clean the system.... *However if you do not know how or have access to a service person... *Then return to SB for service.
    AM
    Feb 2009
    8
    Quote Originally Posted by 123D3436211E323D3234363E363D27530 link=1235370947/5#5 date=1235384467
    AM
    Ill try to clean it thoroughly!! Do I need to remove the group head? Is it juz screw it off? I hv never ever do it b4......sorry mate, im so stupid... :-?
    Feb 2009
    8
    I hv finished the whole process of descaling, but it still doesnt work.
    The water flow has only 50~100ml per times (manual)!!
    So should I bring it back to SB center? But it is already out of warranty... :-/
    10,496
    It depends on which state you are in and how far out of warranty.
    Feb 2009
    8
    Quote Originally Posted by 1F233E252F2E392C242F4B0 link=1235370947/8#8 date=1235453207
    Im in NSW, n thr center is very close to me~
  1. Sunbeam EM6910 Lights Flashing Forever
    By runfast in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 30th December 2013, 05:08 PM
  2. Sunbeam EM6910 Problem
    By drumatic87 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 15th August 2010, 09:11 PM
  3. Sunbeam EM6910 Frothing Problem
    By lsimpson4 in forum Milk Froth and Bubbles
    Last Post: 22nd April 2009, 12:26 PM
  4. Sunbeam EM6910 GH Screw Problem
    By SlikPick in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 27th May 2008, 12:55 PM
