Results 1 to 5 of 5
Thread: EM6910 descaling
    Mar 2009
    2
    EM6910 descaling
    hi,
    Im new to these forums, so sorry if this is a bit of a noob question.
    Ive had my machine for about 6 months or so, no problems but I thought I should descale it. Step 3 in the manual says to remove the filter/screen. Ive removed the screw, but I cant get the filter off. Should it just fall off? Or is there a trick to popping it off?
    Thanks.
    Mar 2009
    2
    Re: EM6910 descaling
    Woops, my wife found the answer just as I had posted this (hangs head in shame).
    For anyone interested:
    http://coffeesnobs.com.au/YaBB.pl?num=1235269539
    A_M
    A_M is offline
    Mar 2006
    6,381
    If you going to do a full descale...
    I would remove the Anti-calk filter from the water tank as well. Just remember to put it back later.
    Sep 2008
    759
    AM,
    I did a full descale on the weekend. The manual made no mention of removing the calc filter and I didnt think of it until Id finished.
    Any idea on the consequences of not removing it? Coffee tastes fine, no stomach upsets either...
    A_M
    A_M is offline
    Mar 2006
    6,381
    Yea ... I know the Manual is lacking ;)
    My only assumption is that the de scaling solution... May have a less than positive impact on the life of the Anti-Calk filter...
    Interesting to call SB and see what they say ;) If they state that you should then.. I guess you could suggest they send you a replacement...
    Then again, it may not be an issue ????
  1. advice on descaling em6910
    By brett0004 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 4th November 2015, 03:39 PM
  2. 2 questions about descaling the EM6910
    By ezralimm in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 3rd April 2010, 11:24 AM
  3. Descaling solution still in water after descaling em6910
    By CaffieneHit in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 30th May 2009, 06:00 PM
