Results 1 to 8 of 8
Thread: Storing Silvia
    May 2008
    69
    Storing Silvia
    Hi,
    Im looking at storing my Rancilio Siliva for a while....(could be up to 6 months) Just wondering what I need to do...
    Do I need to empty the boiler?
    Ed
    May 2008
    69
    Re: Storing Silvia
    wow! was that a really dumb question ?? :P
    Feb 2008
    48
    Re: Storing Silvia
    Nup.
    Id like to know too. Im also going away for 6 months and am wondering the same thing. In the absence of knowledge from the gurus, I think I will see about draining my boiler and letting everything dry out, but I have no idea how to do this at the moment. An argument for not draining everything might be that the seals might be better kept moist????
    Ignorance is NOT bliss!!!! :-/
    Apr 2006
    4,126
    Re: Storing Silvia
    Not a dumb question...I know its been spoken of here before...
    Personally, Ive had long periods of not using my machine (for one reason or another...) and have not emptied the boiler at all...
    Ill suggest a search meanwhile and see if I cant chase one of the lads in here to help... ;)
    Apr 2006
    4,126
    Re: Storing Silvia
    Ok...found this one on the last page...
    Hmmm....will be back with the right link...though its on page 19 if you can be bothered to look...
    Apr 2006
    4,126
    Re: Storing Silvia
    http://coffeesnobs.com.au/YaBB.pl?num=1174111950
    17,098
    Re: Storing Silvia
    Its probably not a big deal if youre just going to store Silvia in a safe place in the back of a wardrobe, etc. Just prime the Boiler in the usual way via the Steam Wand (using filtered water) at your last session of use. Give her a good clean, empty the drip tray, etc; place a protective cover over her and then store it away in an upright position.
    When you get back home, pull her out of storage and re-prime the boiler to completely replace the old water with nice freshly filtered water. And then away you go.... :)
    If you are storing Silvia in a location that may result in her being tipped upside down, then Gregs solution from the thread that Scoota provided is probably the best way to go.
    Cheers :)
    Feb 2008
    48
    Re: Storing Silvia
    Thanks scoota gal, Mal and Greg! *:) I am going to go Mals route, I use filtered water so there is not going to be much in the way of bacteria or fungi in there I hope (and Ill leave it on for a while so the 108 degrees will get rid of most life forms anyway). So in the final analysis, storing Silvia with water in is no different from using her daily except for the heat and the change of water. Corrosion wise, probably no heat is better.
  1. Storing Grinds
    By forrie in forum Roasted Bean Storage
    Last Post: 24th May 2011, 09:34 PM
  2. Storing Shots
    By He_Brews_Espresso in forum General Coffee Related...
    Last Post: 26th July 2010, 08:45 PM
  3. Storing beans
    By dippy1 in forum Roasted Bean Storage
    Last Post: 11th August 2007, 09:30 PM
  4. Roasting and Storing
    By LiquidHeaven in forum Roasted Bean Storage
    Last Post: 13th August 2006, 07:30 PM
  5. Storing / Emptying a Silvia
    By newbean in forum Brewing Equipment (non-machine specific)
    Last Post: 30th March 2005, 05:16 AM
