Results 1 to 5 of 5
Thread: Gaggia Classic question
    May 2008
    16
    Hi I recently aquired a second hand Gaggia Classic.
    As it was kinda old I took off the shower screen to clean it and then put some descaler through it.
    My question is - there are 4 holes under the shower screen but water only comes out of 1.
    Is this right or are the other 3 blocked?
    Also, can I remove this second piece to unblock it? I have tried but it seems irremovable.
    Dec 2008
    60
    Re: Gaggia Classic question
    yep the other 3 will be blocked..get an Allen key (might be 4 mm) and remove the 2 Allen screws that hold that 4 hole manifold onto the group head..easy done and youll be able to do a much more thorough clean
    May 2008
    16
    Yeah I have removed the 2 screws but it still is really tight, I think it must be really gummed up. So I guess if I give it a bit of force it should come off and not break any other part?
    A_M
    A_M is offline
    Mar 2006
    6,381
    There is always a risk!!! With everything..
    Advice is given with best intentions BUT NO Responsibility, as to the outcomes...
    Dec 2008
    60
    mine was a little stuck too...but with a small amount of force it will come away...but as AM says...at your own risk...from memory I simply put a smaller Allen key into on of the holes and levered it ..it popped away from the group without any real trouble...
  1. Replies: 6
    Last Post: 15th March 2012, 08:20 PM
  2. Replies: 4
    Last Post: 10th December 2011, 11:23 AM
  3. Gaggia Classic portafilter and GAGGIA PROTEO ROMANZA
    By cazby in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 24th October 2011, 05:50 PM
  4. Crema question - gaggia classic
    By DomCoff in forum General Coffee Related...
    Last Post: 13th February 2008, 12:39 AM
