Results 1 to 8 of 8
Thread: Another Gaggia Question
    Mar 2009
    6
    Hello People
    So I have cleaned my Gaggia Classic and my grinder has arrived. I am getting a nice fine grind and am able to do a nice even tamp. However these is still one problem, the flow is way too fast and the resulting shot is bitter and the crema seems thin. I had a look around the forum and saw that the Classic has a high factory pump pressure setting, could this be at fault here?
    Site Sponsor
    Aug 2006
    929
    Re: Another Gaggia Question
    Outbreak:
    Could be the following:
    * Grinder still to coarse
    * Need a better tamper
    * Not putting enough coffee in the basket
    * The coffee is bit to old
    I will use the 30 sec 30 ml rule of extraction as an indicator.
    Good luck
    Renzo
    Mar 2009
    6
    - The grind is almost like powder it seems like the grinder is as far as it can go without the burrs touching
    - I have a bumper tamper that fairly heavy and seems like good quality
    - I will try and put more coffee in the basket.
    - The coffee was roasted 7 days ago.
    I will test the 30 sec for 30ml rule, thanks for you help!
    Mar 2009
    6
    I just went and put around 17g of grinds in the portafiller for a double shot and I am not sure what I did differently, but the shot pulled a lot slower and the difference in taste is amazing!! The shot looked like guinness just after it has been poured. I think I just pulled my first proper shot! Around 25 seconds for the double shot, I was going to take a picture but it tasted too good.
    Site Sponsor
    Aug 2006
    929
    Now all what you need to do is the same every single time.
    Enjoy, glad the same of the suggestions help
    Renzo
    May 2008
    16
    I also have a Gaggia and have 2 questions.
    1. is the 30 seconds counted from the time you flick the switch
    2. if I am using the double basket should I be pouring 30ml in 30 sec or 60ml
    Thanks.
    Site Sponsor
    Aug 2006
    929
    Hi;
    From the time the you flick the switch and yes 60ml or 30ml in each glass
    http://www.dibartoli.com.au/product_details.asp?pid=74
    regards
    Renzo
    May 2008
    16
    So Im chasing 60ml in 25-30 seconds for a double.
    Thanks Di Bartoli
  1. Gaggia Carezza Steam Wand Question??????
    By Photogypsy in forum Brewing Equipment (non-machine specific)
    Last Post: 7th December 2012, 08:12 PM
  2. Replies: 6
    Last Post: 15th March 2012, 08:20 PM
  3. ok, new question - gaggia vs nemox?
    By melr in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 28th May 2010, 10:48 PM
  4. Gaggia Classic question
    By steveburge in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 22nd March 2009, 10:23 AM
  5. Crema question - gaggia classic
    By DomCoff in forum General Coffee Related...
    Last Post: 13th February 2008, 12:39 AM
