Results 1 to 5 of 5
Thread: Gaggia Classic-small leak from group when steam running
    Dec 2008
    60
    Whenever I steam my milk a small amount of water drips out of the group from the shower screen...has only been happening for a few weeks..does anyone know what may be failing? The machine is backflushed every 2 weeks or so..
    any Classic owners had this occur? what part fixed it?
    ta
    Dec 2008
    60
    Re: Gaggia Classic-small leak from group when steam running
    *bump* :-?
    May 2004
    439
    Odd. If backflushing hasnt fixed it, then Id suspect the solenoid isnt sealing off properly.
    What happens if you switch on the pump when in steam mode (with the steam valve closed? Does water stream out?
    If it is the solenoid, I think one member got a new one from Barazi else CoffeeParts should be able to help. Both are site sponsors.
    Site Sponsor
    Aug 2006
    929
    I agree with Kaanage, the solenoid probably is not sealing properly, back flash first and see what happen. Secondly put is a part and give it a good clean. Third replace the solenoid.
    http://www.dibartoli.com.au/products.asp?cid=49
    Good luck
    Renzo
    Dec 2008
    60
    cheers gents Ill do as suggested and cross my fingers no $ have to be spent
  1. Gaggia Classic leaking steam from group
    By Spelunx in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 15th February 2008, 11:12 PM
  2. Gaggia Carezza running out of steam
    By NewToEspresso in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 7th June 2007, 11:05 AM
  3. Gaggia Classic pump leak
    By dkelly60 in forum Brewing Equipment (non-machine specific)
    Last Post: 4th October 2006, 11:10 PM
