Results 1 to 3 of 3
Thread: Silvia 2009 & Ibertial Challenge - right grind ?
    Mar 2009
    9
    Ive purchased the Silvia and Ibertial Challenge grinder, still waiting on the Grinder, also have the pullman tamper.
    Just wanting to know what setting on the grinder should I start with for the Silvia standard double basket ?
    Once I get the right grind, is it set and leave or do I need to change settings for each use ?
    If I need to change for each use, or different times of the day, then does that mean that I waste the beans to get the right grind ?
    Do I also need to change grinder settings when I use different beans ?
    Type of coffee use is Espresso and Machiato drinks.
    All help would be very much appreciated.
    Sorry for being a nob..... Daniel
    Jul 2004
    2,130
    Re: Silvia 2009 & Ibertial Challenge - right grind ?
    Hi Daniel,
    Congrats on the purchase.
    The grind you will need does indeed depend on a few factors and will change as the days (and even the hours) pass.
    Starting point - Most grinders markings will differ, so you will hear talk of how the grind feels in your fingers. To begin, try to get a grind that feels like beach sand. Do your stuff and see how it comes out. To begin wth, try for the 60ml in 30 seconds (for a double) from the time you hit the brew switch on the Silvia.
    If it chokes the machine, grind a bit coarser and if its a gusher, go a bit finer.
    You do get the hang of your own grinder pretty fast and you get to the point when you know if a big or small adjustment is required.
    Whether you decide to sink a shot or make the adjustment for next shot is up to you and largely depends on how far out it was.
    As beans get older and weather conditions differ, the grind usually needs fine tuning. Again, you will probably pick these things up the more experience you get with your setup. Often I will make slight adjustments when using the same bean over a week, but when I move to a different bean, the change can be more dramatic.
    There really is no magic setting. For great coffee at home, its a continuing process of monitoring, learning and above all enjoying!
    Have fun!
    Brett.
    17,123
    Great advice "fb"... [smiley=thumbsup.gif]
  1. Iberital Challenge Grind Tuning
    By Lezzare in forum Grinders
    Last Post: 29th July 2012, 06:43 PM
  2. Iberital Challenge - Grind not fine enough
    By paulie75 in forum Grinders
    Last Post: 24th July 2008, 07:39 PM
  3. Silvia & Rocky or Challenge
    By tsk in forum Brewing Equipment (non-machine specific)
    Last Post: 31st March 2008, 11:32 AM
  4. is an iberital challenge a good match for Silvia
    By spoonman in forum Grinders
    Last Post: 12th January 2008, 09:37 AM
  5. Replies: 5
    Last Post: 31st July 2007, 12:47 PM
