Results 1 to 6 of 6
Thread: Brasilia Lady
    May 2008
    86
    Brasilia Lady
    Hi Guys
    have a brasilia lady and would like to find out the best way to make coffee and froth the milk.
    I press the button but steam dies off pretty quick
    any suggestions?
    i have seen some posts a while back about the brasilia lady but i didnt have one back then
    cheers
    Feb 2009
    275
    Re: Brasilia Lady
    Hi LB,
    Im no expert on anything much but you do seem to be overlooked.
    The Ladys function should be pretty much the same as any single boiler machine, like a sylvia for instance, so any Silvia advice should be applicable, try a search read through threads like the one below or search out some *Utube Silvia videos, something may come to you
    http://coffeesnobs.com.au/YaBB.pl?num=1249093026/26#26
    Otherwise I would say you need to provide more info, as the experts seem to be otherwise engaged.
    What Espresso machine have you used previously, with success?
    How long do you wait after switching the boiler to steam before you start milk steaming?
    Do you have any indication that the machine begins heating once you press the steam button?
    2 possibilities here:
    1 my Qs may eventually lead us to a solution.
    2 My Qs may flush out an expert to let me know how niave and stupid my Qs are.
    Any bets?
    Good luck mate, youve waited too long for a latte.
    Lindsay
    Jun 2008
    1,520
    Re: Brasilia Lady
    i have one, but am selling as i upgraded
    great little machine, solid performer
    heres a pic you can see the green light left of the buttons
    http://coffeesnobs.com.au/YaBB.pl?num=1242195366/0#0
    on mine the steam button is on a "timer"
    mine also has a green light that comes on when the steam is ready
    heres what i do
    make shot and flush Ghead etc.
    press steam then pour milk in jug.
    wait for light then purge steam wand of water
    start steaming
    when light goes out press steam button again while steaming
    light comes back on (you can hear the element "boiling"
    if needed press again (normally takes 3 presses)
    i then wait for the light to go out before closing steam wand
    but often you "time" it right so the light goes out at the end as you can keep steaming a while after the light goes.
    after steaming I ALWAYS REFILL / PRIME THE BOILER
    also try taking off the steam nozzel and cleaning it with a scewer etc, mine likes to get gunked up inside :(
    i have a e-copy of the manual if you want it but you need to PM me your email address
    hope i helped
    Leeham
    May 2008
    86
    Re: Brasilia Lady
    cheers Leeham i will PM you
    and Lindsay thanks for getting the ball rolling!
    Feb 2010
    1
    Re: Brasilia Lady
    Hi, I have some issues steaming, Ill PM you for the manual as well if it is OK?
    Jun 2008
    1,520
    Re: Brasilia Lady
    just sat down at the lappy :) and saw this post
    have emailed to you :) as requested
  1. Brasilia Lady
    By latte_boy in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 18th June 2012, 03:07 PM
  2. Brasilia lady
    Last Post: 19th May 2012, 02:09 PM
  3. Brasilia Lady
    By latte_boy in forum Brewing Equipment (non-machine specific)
    Last Post: 1st July 2008, 12:40 AM
  4. Brasilia lady
    Last Post: 8th May 2008, 11:13 PM
