Results 1 to 3 of 3
Thread: EM6910 blockage problem
    Nov 2009
    1
    Hope someone can help/ I have run the cleaning cycle a couple of times, and without coffee in the basket water runs through okay. As soon as I put coffee in, the pressure gauge maxes out, and no coffee comes through. Ive tried different coffee, tamping/not tamping to no avail. Any help greatly appreciated.
    10,496
    Re: EM6910 blockage problem
    How long have you been using the machine?
    Are you using the single-floor or double-floor basket?
    When you say cleaning cycle are you using the rubber cleaning disk?
    P.S. Welcome to Coffee Snobs.
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 31322D2D243B325D0 link=1258262939/0#0 date=1258262939
    1: What cleaning cycle ?
    2: What cleaning agent ?
    3: When did *you last do a correct back flush
    4: When did *you last do a correct descale
    5: Have you ever removed and cleaned the shower screen
    6: How old and how often have you used the unit
    7: What grinder and beans are you using
    8: Which baskets are you using ?
    9: There are 3 digits stamped into the black lable of the unit that you can see after you open the rear door fully up... What are these 3 numbers...
    10: Where did you buy it from
    With most of these answered... Use the search function - part 4 http://coffeesnobs.com.au/YaBB.pl?num=1257241858 and you should be able to work out many of the issues at hand..
    Last of all where are you located..
  1. EM6910 problem...
    By rooeey in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 3rd June 2012, 08:00 AM
  2. 0480 blockage
    By inego in forum Grinders
    Last Post: 21st October 2011, 04:16 PM
  3. EM6910 problem
    By melon in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 9th May 2010, 07:14 PM
  4. Em6910 problem
    By mmmcoffee in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 9th May 2009, 10:58 AM
