Results 1 to 7 of 7
Thread: EM6910 steam pump dial
    Sep 2009
    15
    Hey everyone,
    just noticed this week that my steam dial/knob on my EM6910 is not working properly in that when i rotate it to turn it on there is a little click about 1/3 of a turn into the rotation that causes it stop the steam. The knob is also loose compared to the hot water knob. I feel like its going to pop out of the unit.
    the question is, is it safe to open the unit and have a look? Is it hard to get access to that area? anyone got photos?
    Boots
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: EM6910 steam pump dial
    Quote Originally Posted by 7479796265160 link=1258440258/0#0 date=1258440258
    Hey everyone,
    Boots
    1: Where are you located
    2: How old is it
    3: No need to pull the system apart...
    4: Steam knob pulls straight off... Squease with left hand and then pull. If ya Right handed you may struggle a bit ;D
    Then look at the main fitting etc ... With a torch you will see a small screw - Bet the little screw has become loose.
    Feb 2009
    North Rothbury, NSW
    1,104
    Quote Originally Posted by 456A63617649656A65636169616A70040 link=1258440258/1#1 date=1258440678
    Sounds like it has rotated on the spline as well if steam is clicking off after a third of a turn. You will need to reset it properly on the spline then tighten.
    Sep 2009
    15
    hi guys
    thanks for the quick replies
    I am in Quakers Hill Sydney Ill try to remove the handle and go from there.
    Thanks again!
    Feb 2009
    North Rothbury, NSW
    1,104
    Hey boots
    Im in Kellyville...
    Sep 2009
    15
    hey CKSYD,
    nice one, we are building in Rouse Hill, even closer to you! how do you find your Espro tamper compared to the supplied one? Found any good local roasters or coffee shops?
    By the way, thanks OlSmokey - Im fixed and functioning seemingly better than ever. I almost poured a decent rosetta after the fix too!
    Cheers everyone.
    Boots
    Feb 2009
    North Rothbury, NSW
    1,104
    Quote Originally Posted by 6A67677C7B080 link=1258440258/5#5 date=1258443658
    hey CKSYD,
    Boots
    Espro tamper is very very cool compared to the Sunny one. Sunbeam one is okay (better than many supplied tampers) but Espro, Pullman etc are a level or two above.
    As for roasters, never looked. We roast our own. We are a pickup point for beanbay green/brown beans, teas cocoas etc. click on buy green/buy brown and you will find out all about it.
    Good coffee shops? ;D Not out here but again dont go looking ;D
    PM me Ill give you the address and you can play with the Espro. Ill explain beanbay over a nice coffee if you like.
  1. EM6910 no main pump, low hot water and steam pump. Had red light. now just not worki
    By bocos in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 9th February 2013, 08:25 AM
  2. installing new steam pump in em6910
    By crazyhakins in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 27th April 2012, 07:24 AM
  3. Sunbeam EM6910. Steam pump going but no steam? Just water!
    By samdasurfinman in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 5th March 2011, 09:08 PM
  4. Em6910 Steam pump settings
    By TMeldrum in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 17th December 2009, 05:15 PM
  5. Steam Pump Problems EM6910 (noob)
    By zerogeewhiz in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 26th June 2009, 08:18 PM
