Results 1 to 16 of 16
Thread: 6910 pulsating pump
    Aug 2009
    179
    6910 pulsating pump
    Hi all, been working up the sunny coast fro the last month so Ive been away from my 6910 ( bugger ). Anyway , I think its starting to develop a problem. When pulling a shot, it starts as per normal with its pulsing, then after about 5 seconds the pump goes quiet ( still running), the pressure gauge drops, then it starts to pulse up and down about 3 times ( with the pressure gauge moving up and down ),then it settles down and gives normal performance. Not right IMO. Time for a sunbeam call ? The machine was bought in October this year, with a 4 year warranty ( might be needing it eh). The machine makes about 6 cups a day on average. :-?
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: 6910 pulsating pump
    Quote Originally Posted by 575641415A5F564B330 link=1260944108/0#0 date=1260944108
    Hi all, been working up the sunny coast fro the last month so Ive been away from my 6910 *( bugger ). Anyway , I think its starting to develop a problem. When pulling a shot, it starts as per normal with its pulsing, then after about 5 seconds the pump goes quiet ( still running), the pressure gauge drops, then it starts to pulse up and down about 3 times ( with the pressure gauge moving up and down ),then it settles down and gives normal performance. Not right IMO. Time for a sunbeam call ? The machine was bought in October this year, with a 4 year warranty ( might be needing it eh). The machine makes about 6 cups a day on average. :-?
    Sounds like crap around the solinoide / 3 way valve..
    When did you last do de scale and group flush???
    From my ibrick
    Aug 2009
    179
    havent descaled it at all yet as its only 2 months old. I do a group head flush after every brew using the rubber insert, as recommended by the girl who ran the coffee school.
    Mar 2008
    433
    Has been asked and answered before.
    This "can" be a result of too fine of a grind and underdosed puck. Coarsen your grind a bit and put more coffee in the group handle (actualy, coarsen the grind a lot) and then maintaining the same level of coffee, slowly make the grind finer again until you get the right pour.
    Mine does this from time to time when I get the level wrong in the basket.
    Sen
    Aug 2009
    179
    Ill give it a go, thanks. BTW, do HN stock the cleaning solution/tablets required for the 6910 ?
    Aug 2009
    179
    Ok, so I did as you said Senator. I ran my 480 grinder dry, filled the hopper with fresh beans and pulled 4 gushers, getting finer each time, until.....on the 5th shot ( getting better but still a gusher) as soon as the gauge hit 1 oclock it started to pulse again. I kept going finer to get a better shot and it pulsed for longer each time before stabilising. Each time it pulsed as the gauge reached 1 o clock ??? I might ring the hotline and see if they will replace the machine. 2 months old, Im not willing to have it repaired, unless it takes 1 day. NOT HAPPY JAN. >:( >:( >:(
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 3C3D2A2A31343D20580 link=1260944108/2#2 date=1260953665
    WTF... I only did that every other day... But about once a week / 10 days did a chemical group head flush...
    If coffee fines get into that valve... Then the gauge will pulse and can stop working...
    Other than that... Dose / grind and Tamp can cause the problem..
    Where is ya Sweet spot and where do you get the Good Shot when all working ?
    Aug 2009
    179
    SS is about 12.30 and good shot is about 1.30 when it was working properly.
    Feb 2008
    5
    .....I do a group head flush after every brew using the rubber insert, as recommended by the girl who ran the coffee school. [/QUOTE]
    Wouldnt tend to loosen material on the shower screen and possibly lodge in the 3 way valve?
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 48495E5E454049542C0 link=1260944108/7#7 date=1260962356
    Can only recommend you perform a chemical back flush and see how it goes...
    Aug 2009
    179
    Ill do a chemical back flush and a full descale and see what happens. As soon as any real load is put on the pump it dies.
    Aug 2009
    179
    Ok, full descale with not much crap coming through the machine ( as expected been 2 months old ) Group head flush with tablet, got a fair bit of brown liquid. Tried pulling a shot....... exactly the same. Taking it back to HN and not leaving unless its with a new machine.
    Aug 2009
    179
    Well, I WON I WON I WON. Sitting in front of me is a new machine. I walked into HN and told them to call the sunbeam rep because Im not leaving unless its with a new machine. After a few rounds of it will have to be sent away - NO NOT GOOD ENOUGH, they did a test on it and agreed it was faulty, and since it couldnt be fixed instantly the rep authorised a new machine. SWEET AS.
    A big thumbs up for the 2 IC @ Harvey Norman Oxley ( brisbane). Be persistant, and get what you paid for. Let this be a precident for any others with a faulty new machine. ;D ;D ;D ;D ;D ;D ;D
    Mar 2008
    433
    well done.
    hopefully this one behaves for you
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 717067677C79706D150 link=1260944108/12#12 date=1261023283
    Well, I WON * * I WON * * I WON. Sitting in front of me is a new machine. I walked into HN and told them to call the sunbeam rep because Im not leaving unless its with a new machine. After a few rounds of it will have to be sent away - NO NOT GOOD ENOUGH, they did a test on it and agreed it was faulty, and since it couldnt be fixed instantly the rep authorised a new machine. SWEET AS.
    Tis good...Now did you pick up cleaning tabs etc and have you checked ya Sweet Spot and Good Shot spot.. Be interested to know of ya findings...
    Aug 2009
    179
    Yup. Ive got the tablets for the group head and the descaling liquid. The SS is @ 11 and GS @ 12.30. God Im happy, it must be xmas. ;D
  1. 6910 spontaneous pump startup
    By Neil_sullo in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 16th June 2012, 04:21 PM
  2. 6910 pump continuous running ...
    By pbange in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 19th May 2012, 05:46 PM
  3. Sunbeam 6910 pump pressure
    By aussiedean in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 24th February 2011, 02:12 PM
  4. Sunbeam EM 6910 pump starts by itself!
    By Rodders in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 20th July 2009, 09:19 AM
