Results 1 to 5 of 5
Thread: Dribbling wand.
    Oct 2009
    Perth
    26
    Dribbling wand.
    Hi,
    My 2009 V3 Silvia is only a few months old.
    Lately I have noticed that the steam wand is dribbling about 1tsp of water during heat up.
    In other peoples experience is this normal, is it residue in the wand, or possible a seal worn out very prematurely?
    Is there anything I should do to prevent it getting worse?
    Regards
    BaryBC
    Jan 2008
    1,756
    Re: Dribbling wand.
    Hey there, do a search, its normal fir a Silvia during warm up. Turn on, tighten steam knob or face the very real possibility of a burnt out boiler element, have a great day ;)
    Oct 2009
    Perth
    26
    Re: Dribbling wand.
    Hi WSully, thank you for the info.
    I have read enough posts now to always search before posting:)
    My concern is that it only started happening over the last few weeks. I also read plenty on how to fix it, suggesting it is a problem.
    I was concerned that over tightening was going to shorten the life of the washers. Or I may have debris stuck in there.
    Regards
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: Dribbling wand.
    Quote Originally Posted by 0724373C0706450 link=1260948029/0#0 date=1260948029
    Hi,
    Regards
    BaryBC
    AND
    Quote Originally Posted by 0724373C0706450 link=1260948029/2#2 date=1260954237
    Regards
    Always follow the correct search method.. see here.. http://coffeesnobs.com.au/YaBB.pl?num=1257241858
    In addition ya first post did not indicate that you knew what the problem was.. You were asking for advice as to the problem..
    Ya second e-mail is about what impact doing the mods will have..
    If ya follow the correct procedures etc should not be a big issue... If you OVER TIGHTEN.. and go too heavy handed... Then that is a different manner..
    dex
    dex is offline
    Feb 2007
    28
    Re: Dribbling wand.
    My Silvia would do this all the time so I put a small jug under the nozzle. I think it is caused by the metal cooling down and contracting leaving the valve open slightly. I would just pinch it up the next time I turned her on.
    Dex
  1. Replace old Lelit wand with new Ball-joint wand?
    By lukewarm711 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 9th September 2012, 05:37 PM
  2. Dribbling Gaggia Classic
    By sluggo33x in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 7th July 2008, 07:14 PM
  3. Changing Steam Wand Gaggia Classic to Silvia Wand
    By pricespringer in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 3rd May 2008, 12:53 PM
  4. [m]: Changing Steam Wand Gaggia Classic to Silvia Wand
    By Dimal in forum Milk Froth and Bubbles
    Last Post: 23rd April 2008, 03:33 PM
