Results 1 to 6 of 6
Thread: gaggia not brewing!
    Dec 2009
    3
    gaggia not brewing!
    hi peoples,
    my gaggia platinum vision which will only make a full brew every 3rd attempt. any ideas? would it be the brand of beans? has anyone else had this problem?
    cheers
    Jun 2008
    1,520
    Re: gaggia not brewing!
    when you say attempt what do you mean?
    how old is it, when did you last clean and service it?
    is it under warrenty?
    what sort of beans and when / where did you buy them?
    lastly, has it ever made good coffee?
    provide more info for better help :) and welcome to CS
    Dec 2009
    3
    thanks glad to be aboard.
    ive had it 6 months
    cleaned it 3 times in the last week
    vittoria mountain grown beans
    it gets half way through brewing and water comes to a dribble and steam starts blowing out of the head
    Jun 2008
    1,520
    I have no real idea Starkers as its a super auto.....some one else may be able to help but we as a group shy away from superautos...
    try making the grind finer or dose less (if you can?) have you changed type of beans being used? it might then need adjustment to grind / tamp if they are a lot diff
    if it keeps doing it i reckon it would then be a mechanical issue maybe a seal is split and leaking or however it "closes" to brew is not closing?
    hope you have some warranty.....
    Dec 2009
    3
    thanks for your help. i try some new beans and see how i go
    cheers
    Dec 2009
    2
    sounds asthough your beans are groung to fine. Water is struggling coming through your coffee. A weak piont on your machine is the steam tap, you will notice when it gets warn as it will drip out of steam arm whilst making a coffee. Thanks
  1. Newbie to Gaggia Classic - brewing problems
    By KimDD in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 18th September 2011, 07:33 AM
  2. Help with my brewing....
    By mgrobins in forum General Coffee Related...
    Last Post: 24th June 2011, 02:10 PM
  3. Best brewing methods
    By New_Bean in forum Brewing Equipment - Manual Coffee Brewing Processes
    Last Post: 10th August 2009, 06:04 PM
  4. Gaggia Classic brewing group and hot water problem
    By aleph in forum Brewing Equipment (non-machine specific)
    Last Post: 15th December 2006, 04:05 AM
