Originally Posted by
6559445F555443565E55310 link=1262052852/2#2 date=1262087536
Have you tried installing it again to make sure its in right?
Yep got to it again the other day and it does the same thing, thats why i thought that maybe there are 2 different thickness spacers, one for the 6900 and one for the 6910?
When you say you used cardboard what sort do you mean, something like from a cereal box thickness wise? Theres no way a normal box thickness would work, thats be worse then the Si spacer.
I have an old main seal that I replaced ~6 mths ago to counteract the collar wear a bit, I should try that worn (but not damaged) one with the spacer to see if that helps.
PS. I would just replace the collar
IF I could find one to buy, so if anybody knows the whereabouts of one for sale please let me know.
