Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By A_M
Thread: em6910 collar replacement
    Jan 2010
    2
    Hello
    Ive just disassembled my Sunbeam em6910 to replace the group head collar that was leaking. I went to fit the new collar and discovered that the screw holes on the new part are smaller. Apart from the holes being smaller the only difference between the new and old collar is that the old collar has the letters VH cast into it and the replacement has VD
    Have I inadvertently purchased the wrong collar? I rang Sunbeam to obtain the part number before I purchased the collar from the local dealer. The number I was given for the collar was EM69146. Does anybody know if this is correct?
    In addition to the above the copper tube that connects the body of the group head (thermoblock?) to the solenoid was loose. Has any body else had this part come away before?
    Regards
    10,496
    Re: em6910 collar replacement
    Quote Originally Posted by 454D16191110200 link=1263987614/0#0 date=1263987614
    I cant confirm because my Spare Parts List skips that number.
    However that could just mean my list is old or that the number is on a different list.
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 635F4259535245505853370 link=1263987614/1#1 date=1263990345
    Reading off a NEW one as I type...
    EM6910106 *approx $55
    Do a search and find the extensive posts by Matrix and myself as to replacing the collar etc.. Lots of instructions and pics.
    1: Where are you located ?
    2: Get a licensed electrician to check the unit before turning back on
    netsledek likes this.
    Jan 2010
    2
    Im in Canberra. The local service agent only supplies parts and does not work on Sunbeam Machines.
    I think the leak may have been from the copper tube that has come away and not the collar. How do I reattach the nipple? (See photos). It appears that nipple should be part of the thermo block and the collar is a captive part. *As the nipple has come away the collar is off also. Does this mean I need to purchase a new thermo-block? The problem seems to have occurred because the mounting lugs interfere with the collar when it is tightened.
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 464E151A1213230 link=1263987614/3#3 date=1265435686
    As to teh above.. Never seen that or where the lugs interfear...
    As to the break.. WARRANTY unless it was done by you or some one else..
    Apr 2011
    1
    Very helpful thread - thankyou to everyone.
    I am writing to ask whether the process outlined in the EM6910 Collar Replacement Guide is the same for the EM6900?
    Any advice would be appreciated.
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 446562647C7552627567100 link=1263987614/5#5 date=1302239547
    In essence teh same.
    Problem can be that the new collar may have slightly different hole sizes as Sunbeam increased teh size of teh screws. Why, because the early ones did strip / pull out when people overdosed and forced things.
    So if your screws are OK, you should be fine. But if any are stripped or corroded then get some new ones as well.
  1. EM6910 Collar Replacement. A How To Guide
    By wan in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 3rd March 2019, 01:29 PM
  2. Sunbeam 6910 Collar Replacement
    By clubbi4 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 2nd July 2017, 06:11 PM
  3. EM6910 New Collar
    By rich00 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 7th September 2009, 10:33 AM
