Results 1 to 10 of 10
Thread: Descaling em 6910
    Jun 2009
    214
    Descaling em 6910
    Hi guys,
    I think its time to descale my em6910 for the first time. The manual give options of two way:
    no 1 - sunbeam expresso machine descaling tablets
    no 2 - sunbeam liquid descaler
    Which one do other 6910 owners prefer using?
    Also are there any tips or tricks that i should know about?
    thanks heaps :)
    Feb 2009
    North Rothbury, NSW
    1,104
    Re: Descaling em 6910
    I use Bombora triple action cleaner as that is able to run through the steam arm.
    Note your option No 1, and possibly option 2, which i have not used, the manual says dont run through steam - others have done it and jammed the machine.
    SB descaler will crack the scale off like plaque. Bombora triple action dissolves it.
    So the relevant blurbs go. Im happy with the Bommy as it dissolves the rubbish.
    Hope that helps
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 2C243C362B4F0 link=1264474996/1#1 date=1264595822
    Hope that helps
    Thanks Chris... Handy to know..
    I would still recommend turning the seam settings to the LOWEST temp and the WETTEST settings..
    That way you should also get less steam (so to speak) and a wetter wash through the steam wand... Also do it out side if possible as the fumes may be an issue for some..
    Jan 2010
    1
    Hi, I am new to this and have just joined up. I am still working out whether or not to become a "real" coffeee snob or not. My husband bought me a subscription to Italianiscious and I won a coffee machine. Its a ISOMAC ALBA ! Is this easy to use? .. or do i require classess?
    HelenD
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 404C7D6663646D71080 link=1264474996/3#3 date=1264627637
    Hi, I am new to this and have just joined up. *I am still working out whether or not to become a "real" coffeee snob or not. *My husband bought me a subscription to Italianiscious and I won a coffee machine. Its a ISOMAC ALBA ! *Is this easy to use? .. or do i require classess?
    HelenD
    Welcome HelenD
    I would suggest you Go here http://coffeesnobs.com.au/YaBB.pl?num=1163710607/950#950 and tell us a bit more about your Coffee experiences / background and what Coffee equipment you have *or have used..
    Some might say or imply that making coffee is Hard, while others have a different view.. *But one thing for sure; it is an interesting and long road.
    You may need to update ya profile as to ya location as there could be a CS sponsor or another experienced CS member wioth some spare time... Just around the corner.
    Training may be a great step forward and do some searching and reading.. As the Grinder and Beans etc all have an effect on the outcome.
    PS. What is the mag like... Wife and daughter went back to visit rels and want to go back again...
    Welcome..
    Jun 2009
    214
    Thanks guys,
    Just wondering if i need to remove the anti-calc filter in the water jug. The manual says nothing about it. :-/
    Feb 2009
    North Rothbury, NSW
    1,104
    Quote Originally Posted by 444B505C44414453250 link=1264474996/5#5 date=1264628804
    Thanks guys,
    Hi anu
    I remove it whenever I descale. Dont think you want the solution getting into it.
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 424D565A42474255230 link=1264474996/5#5 date=1264628804
    Thanks guys,
    Ya a good man..
    Manual says - :o :o :o
    I have always removed it.. I thought, better safe than sorry.
    Feb 2009
    255
    Quote Originally Posted by 69667D71696C697E080 link=1264474996/5#5 date=1264628804
    Thanks guys,
    I always remove it.
    Just remember to get all the air out of it when placing it back in the container otherwise you will probably have trouble getting the pump to work properly.
    To do this I partly fill the container with water then put the filter in the container giving it a shake whilst upright to remove the trapped air before clipping back into place.
    10,496
    Quote Originally Posted by 6A66574C494E475B220 link=1264474996/3#3 date=1264627637
    HelenD
    Welcome to Coffee Snobs Helen.
    Nice looking machine that Alba.
    It looks like it has been put together with a standard e-61 type build so to answer your question, "Yes, its easy to use".
    Do you need lessons?
    That depends on how much espresso machine experience you have.
    If little, get some.
    It will make your learning curve less steep.
    (When you tell us where you are we can point you to the nearest tutor we recommend.)
    Some of us have had lessons long after getting into this hobby because you can always learn from someone who knows more.
    I did lessons to decide which first machine to buy.
    Were all different.
  1. Descaling solution still in water after descaling em6910
    By CaffieneHit in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 30th May 2009, 07:00 PM
  2. Removing group head screen for descaling - Sunbeam 6910
    By badge61 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 23rd February 2009, 09:51 PM
  3. Descaling a LSM 85-16M-2...what will i need?
    By Zakal1 in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 15th February 2007, 02:45 PM
