Results 1 to 6 of 6
Thread: EM1690 Diagnosing Worn Collar
    Senior Member Rusty's Avatar
    Apr 2004
    Carlingford NSW
    691
    I must be stupid - I cant any results when I search this subject :-[
    Im getting water coming over of the top of the basket as well as through the spout. Ive checked the seal and made sure the assembly is screwed in tight. The pressure gauge is reading normal at about one oclock.
    Is this symptomatic of a worn collar?
    The unit is still under Sunbeam warranty until June then extended warranty for another four years ::)
    Any guidance would be greatly appreciated as always.
    Feb 2009
    53
    Re: EM1690 Diagnosing Worn Collar
    Hey Rusty, I have the same problem, different machine!!! See next post. Good luck with the fix.
    A_M
    A_M is offline
    Mar 2006
    6,381
    Collar and seal.... *SB may or may not cover it, too many being heavy handed and overdosing... *Call and see how you go ..
    Remember extended does not cover every thing you think it does.. Read the fine print....
    See an earler post of mine, as to how to use the search function.... It will make a big difference.. Hundreds of posts and pics as to the issue and the fix and the cause...
    Forums and I- bricks do not mix.....
    Apr 2009
    42
    Hi Rusty
    I have the same machine; I find this happens if I overload the basket or do not twist the group head far enough to the right. Check that you are leaving about 5mm of space at the top of your basket. Also if the grind is too fine then it will choke the pump and cause it to overflow over the basket. Does the pump stay constant or does it bounce when it reaches 1 o’clock?
    hope this helps ;)
    Sep 2007
    Northlandia
    1,363
    Quote Originally Posted by 183F393E334A0 link=1265508502/0#0 date=1265508502
    I must be stupid - I cant any results when I search this subject *:-[
    Im getting water coming over of the top of the basket as well as through the spout. *Ive checked the seal and made sure the assembly is screwed in tight. *The pressure gauge is reading normal at about one oclock.
    The unit is still under Sunbeam warranty until June then extended warranty for another four years *::)
    Could be due a new g/h seal... If that doesnt fix it a spacer under the seal will buy you time...
    Apr 2004
    Carlingford NSW
    691
    After replacing the seal and finding no improvement I sent the SB in for a new collar under warranty ;)
    Up to two weeks before it comes back :o
  1. Diagnosing roast help
    By senoralastir in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 22nd May 2012, 10:17 PM
  2. Worn burrs? how to tell?
    By artman in forum Grinders
    Last Post: 4th July 2011, 07:47 PM
  3. EM6910 Worn Collar Pics
    By daniel-san in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 13th June 2010, 03:31 PM
  4. EM6910 collar worn
    By Thundergod in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 21st November 2008, 11:20 AM
  5. Should I travel this worn path or not?
    By kevthemilkman in forum Brewing Equipment (non-machine specific)
    Last Post: 9th August 2005, 12:29 PM
