Results 1 to 8 of 8
Thread: Follow up to EM6910 Leaking Group Handle
    Senior Member Rusty's Avatar
    Apr 2004
    Carlingford NSW
    691
    I decided to try the SB basket instead of the Synesso. I was surprised that there was no longer a leak ::)
    I still up-dosed but the SB basket takes a bit less so that probably reduced the pressure somewhat - but the gauge went higher :o
    The grind was the same.
    Im thoroughly confused :(
    10,496
    Re: Follow up to EM6910 Leaking Group Handle
    The new Sunbeam baskets have a different profile to the top edge.
    From memory theres a ridge or similar i.e. not flat.
    Maybe thats the difference to your Synesso basket.
    Jan 2010
    59
    Hey guys i dont know if this will help, but i use a double basket i bought from coffee parts in my em6910 and it doesnt have the small ridge on top and i dont get any leaking from the handle. like i said dont know if this will help :-?...hope you find an answer.
    Jan 2010
    26
    Regardless of the ridge, its possible that the top edge of the Sunbeam basket and the basket from coffee parts sits higher in relation to the lugs on the portafilter, compared to the Synesso basket.
    In regards to the pressure, I think the Sunbeam basket has fewer (and perhaps smaller) holes than many other baskets. From memory its not a full grid pattern, but rather a grid with 1 in 4 (or 1 in 9?) holes filled.
    10,496
    Quote Originally Posted by 564A47504746414352514B41574F220 link=1265699645/2#2 date=1265752416
    My Expobar basket also doesnt cause leaking in the 6910.
    Mar 2008
    433
    wasnt there a reference on the Pullman site about the Synesso baskets causing problems with the 6910? (or is my mind playing tricks on me)
    Mar 2005
    2,165
    Right and wrong. There is a reference but it relates to an incompatibility with the single basket and the 6910 portafilter.
    Apr 2004
    Carlingford NSW
    691
    Hi Greg,
    Care to hazard a guess as to whats causing my problem with the Synesso ::)
  1. Sunbeam EM5600: Leaking Group Handle and Tamping
    By BComApplied in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 9th November 2011, 03:43 PM
  2. EM6910 group handle
    By turando in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 8th January 2011, 02:30 PM
  3. EM6910 new group seal and still leaking
    By moreCoffee in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 2nd September 2009, 01:06 PM
