Results 1 to 4 of 4
Thread: Sylvia Steam Thermostat problem.
    Mar 2009
    Bargara, QLD
    49
    I have a pided Silvia. When I turn the steam function on the temperature reading on the pid keeps on going up. I turn the steam off at about 145 deg, but if I didnt, it would just keep going. I think I have seen it up to 180.
    Having just stripped the machine to galvanize the chassis and rebuilt it, I have learned something about the inner workings. Logic suggests that the problem is the steam thermostat. The thermostat is clearly easily replaced.
    My question is: Do thermostats expire?
    Shakin Stevens (its the caffeine).
    16,771
    Re: Sylvia Steam Thermostat problem.
    Quote Originally Posted by 5655404B46445757250 link=1266966290/0#0 date=1266966290
    In a word.... Yes!
    Like any electro-mechanical device, they will wear out.
    Since you have a PID Controller installed, why not use that instead? It will do a much better job than any thermostat and will hold Steam Volume at the optimum level throughout any milk texturing exercise.
    Should give that some thought mate.... ;)
    Mar 2009
    Bargara, QLD
    49
    Thanks Mal.
    Looks like I am going to have to familiarize myself with the PID installation guide to figure it out. But with a bit of head-scratching it has to be do-able.
    Shakin Stevens
    Baraga Beach
    16,771
    Its easier than you probably realise....
    All thats required is to adjust the Setpoint up to a nominal Steam Setting - 125C is excellent - and then adjust it back to the Brew Setting when youre finished. Im sure youll be quietly amazed at the difference in steam performance ;)
  1. PLEASE HELP - Rancilio Sylvia frothing problem
    By mickwhit in forum Milk Froth and Bubbles
    Last Post: 7th November 2015, 04:41 PM
  2. Replies: 4
    Last Post: 15th October 2011, 06:27 PM
  3. Sylvia steam wand always drips
    By stevenc in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 5th June 2009, 09:51 PM
  4. Diadema thermostat problem
    By rowd in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 9th June 2007, 06:18 PM
