Results 1 to 7 of 7
Thread: Descaling Gaggia Classic
    Mar 2008
    69
    Probably a dumb question *- its about descaling a Gaggia Classic. I have some Cafetto - do I put 1 level scoop in the group head (with a blind filter which I have to get) and follow the instructions OR can I put the Cafetto into the water reservoir (mixed) and run the pump a number of times ,let it soak for about 20 minutes and then run pump again in short bursts ? Of course after I would run clean water thru the machine before brewing .
    The reason I asked this that a coffee machine service firm looked at machine to find out about my poor steaming problems and stated that all it needed was a good descale - to do $143 !!!
    Thanks for your help
    10,496
    Re: Descaling Gaggia Classic
    Cafetto is NOT a descaler.
    DO NOT put it in the water reservoir.
    Quote Originally Posted by 1012090305131012090E070512600 link=1267252541/0#0 date=1267252541
    Yes.
    Oct 2008
    488
    Cafetto is a company that makes backflushing detergent AND descaling solution
    10,496
    Quote Originally Posted by 39313E38306A6F5B0 link=1267252541/2#2 date=1267255652
    Read the opening post again.
    They appear to have backflushing cafetto.
    Mar 2008
    69
    So taking this a step further *- The product Cafetto is called Espresso Clean and should only be used to backflush ?. As this drawn *back *inside the machine does this also descale. *Probably not ?
    I was given this product from a coffee shop to help me out - Do commercial machines have to be descaled or just backflushed ?
    10,496
    "Espresso Clean @home is designed to clean, descale and sanitise the brewing group, handles, filters, the milk line system and boilers of domestic and small office machines. It has a unique application where the machine has no programmed cleaning cycle (as distinct from descaling or decalcification cycle) and the brewing group cannot be removed for cleaning."
    Mar 2008
    69
    Quote Originally Posted by 6D514C575D5C4B5E565D390 link=1267252541/5#5 date=1267260934
    So in short I need the Espresso @home product as the granules are not for domestic machines ?
  1. Gaggia Classic descaling
    By richard_s in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 21st August 2010, 11:06 PM
  2. Gaggia Classic Descaling
    By T.D. in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 12th October 2009, 09:04 PM
  3. Descaling Gaggia Classic
    By Sydneywizard in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 18th February 2008, 12:19 PM
