Results 1 to 15 of 15
Thread: To leave on or not to leave on?
    Mar 2009
    62
    Hi guys, I have just upgraded from sunbeam 6910 to a nuova simonelli oscar (thank you Tony Land), and Ive got to say for starters how happy I am with the new machine :D. My question is, if I am home for the day should I leave it on all day? I am inclined to do so and have today without any worries, I just wondered if its the right thing to do with these machines? I figure itll use less power if I just leave it on and let the boiler cycle to keep it at a steady temp (kinda like your air-con unit) rather than turning it on and off a few times a day and really working hard to get up to temp.
    Your two cents worth is appreciated *:)
    Caffeine Junky
    May 2009
    1,103
    Re: To leave on or not to leave on?
    I have an Oscar at the office which gets left on all day. No issues at all with this type of machine. It also encourages you to drink more black gold during the day :)
    Mar 2009
    62
    Ha ha yes it does! Thanks I thought I was on the right track. Also how often should I back flush? I normally do it just with water after every session just to clean the old grounds off the group seal (I like it clean and tidy), is this still ok? I know that with some machines it is not recommended to do it all the time but I couldnt find it in the manual anywhere.
    16,769
    Im not completely au fait with the general arrangement of the internals of the Oscar but given how quickly this style of machine heats up to operating temperature, I dont know why youd want to leave running for hours without use... Its not a commercial machine after all.
    Exposing electrical and electronic devices to high temperatures actually accelerates the deterioration of various intrinsic compounds. The longer this exposure, the greater the accumulated effects. So long as youre aware of this downside, its then up to you whether its worth it or not....
    Site Sponsor
    Aug 2006
    929
    Quote Originally Posted by 5974707C711D0 link=1267939261/3#3 date=1267945079
    Most of the boards that our technician has change, or due to the tare and ware of the component or because people leave their machine 24/7
    Regards
    Renzo
    16,769
    Quote Originally Posted by 14390F123122243F3C39500 link=1267939261/4#4 date=1268000107
    Regards
    Renzo
    I can well understand that Renzo.....
    So-called prosumer machines are just NOT designed to be left running 24/7.... Simple as that.
    Mar 2009
    62
    Ok cool thanks guys. Mal youre dead right too in saying that it doesnt take long to heat up, Ill just turn it off when Im done I think :)
    16,769
    Quote Originally Posted by 3620232136202036370C3A200C31362027530 link=1267939261/6#6 date=1268032830
    Ok cool thanks guys. Mal youre dead right too in saying that it doesnt take long to heat up, Ill just turn it off when Im done I think *:)
    Good one mate [smiley=thumbsup.gif]
    Your Oscar will thank you and reward you with many years of faithful and reliable service... :)
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 0D20242825490 link=1267939261/7#7 date=1268033178
    Only just saw this and the comments above..
    Yep.. On 24/7 for many things is not ideal... While for some items it is teh norm; it is usually about items that draw little current etc.
    Many PCs for example ie. Servers stay on 24/7 and when they are turned off; the power supply usually fails.. Thus a good reason why raid 5 also means extra power supplies. CRTs and LCD monitors are another typical example of a unit that should never be left on 24/7...
    As to the Oscar.. saw two at DiBella a few months back that had cooked and had total melt downs..
    One 24/7 and shoved into a corner in a kitchen with no good air flow.. One even buckled teh whole side panel...
    Some people want that coffee quick in teh morning..
    1: Switch it on and have ya shower and or do other things first first... It will/should be hot enough
    2: Have a timer
    3: Get ya partner to get up first ;D
    And when ya go away for any length of time etc OFF at teh wall. Any short or leak that could trick ya system to come on... Could leave you with a pile of carbon.
    Just ask Coffee2di4 what nearly happened to her roaster.. There is a post some where :D
    Jun 2007
    362
    Quote Originally Posted by 022D2426310E222D2224262E262D37430 link=1267939261/8#8 date=1268046827
    2: Have a timer
    Dont think you can put Oscar on a timer (no vacuum breaker)! Only two options left! Or 3 if you include installing a vaccum breaker.
    16,769
    Quote Originally Posted by 33342F27203235410 link=1267939261/9#9 date=1268053654
    I think Coffee Parts may have a combination Safety/Anti-Vac Valve in their catalogue somewhere. If its possible to fit this in place of the original Safety Valve, that would overcome the problem having her ready to go when your feet hit the floor in the morning.... ;)
    Mar 2009
    62
    Thanks guys, Ill just kick the wife out of bed first from now on hey :P Jokes, The past few mornings ive turned it on before the shower and its right to roll shortly afterwards so I think Ill stick to that method. Would it be a big job installing a vacuum breaker?
    Jun 2007
    362
    Quote Originally Posted by 3523202235232335340F39230F32352324500 link=1267939261/11#11 date=1268133532
    Would it be a big job installing a vacuum breaker? *
    No, it is the last part on this page -
    http://www.dibartoli.com.au/products.asp?cid=47
    There are 2 other 1/4 brass fittings required - if your not that way inclined get a pro to do it or just live with it.
    Mar 2009
    62
    Cheers runfast, i reckon I could sort that out (famous last words).
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 485E5D5F485E5E484972445E724F485E592D0 link=1267939261/13#13 date=1268475167
    Better to say.. Looks simple enough :o
    Rather than;
    "famous last words"
    You may not be playing with electricity directly... But you will be in a place that it lives..
    1: Machine off
    2: Cord disconnected from wall socket
    3: Be carefull with what ya do
    4: Get it tested before thinking about connecting it back up.
  1. Leave Britney Alone!!
    By Yelta in forum Off Topic
    Last Post: 8th September 2010, 07:16 PM
  2. Leave...come back...leave.... come back...
    By Identity in forum Off Topic
    Last Post: 26th July 2009, 10:49 PM
  3. Will leave you happy
    By Sarg in forum Off Topic
    Last Post: 6th November 2007, 11:51 PM
  4. Leave on all day?
    By 69strat in forum Brewing Equipment (non-machine specific)
    Last Post: 21st September 2006, 01:21 PM
