Results 1 to 9 of 9
Thread: EM6910 After Collar Replacememt
    Senior Member Rusty's Avatar
    Apr 2004
    Carlingford NSW
    691
    Just received the SB back with a new collar fitted.
    The group handle is MUCH stiffer and doesnt want to go past the 7 oclock position without really forcing - which Im reluctant to do :o
    Is this normal after a repair, or could there be something not quite right - apart from the operator 8-)
    The shots seem normal.
    Id appreciate comments from those who have had this repair done.
    Jan 2008
    1,756
    Re: EM6910 After Collar Replacememt
    Hey rusty, been a while since ive seen you round these parts! Is it leaking if you dont push it around past 7? if not i wouldnt worry, just enjoy the shorter journey ;)
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 7E7A5C4545405F4847290 link=1268428276/1#1 date=1268430657
    I agree.. The new collar and seal will mean teh system seals better OR your OVERDOSING.
    5cent piece test ;D
    If ya can look at smoothing the step on the lugs with a dremel and and or use a little food grade grease.. I used a dash od Rice bran oil... High temp and food grade.
    If ya forcing it, then you stressing that SOFT material in teh collar.
    AM
    Senior Member bennett's Avatar
    Jan 2008
    294
    Quote Originally Posted by 5F787E79740D0 link=1268428276/0#0 date=1268428276
    The group handle is MUCH stiffer and doesnt want to go past the 7 oclock position without really forcing - which Im reluctant to do *
    Is this normal after a repair, or could there be something not quite right - apart from the operator *
    Mine was exactly the same. I didnt push it and before long it was at 6 oclock then 5 oclock. then 3 months later my PCB died!
    Apr 2004
    Carlingford NSW
    691
    OOPS!
    I forgot to mention that the basket was empty when experiencing the tightness, so over dosing is not the cause.
    Jan 2008
    1,756
    Quote Originally Posted by 6F484E49443D0 link=1268428276/4#4 date=1268453641
    OOPS!
    So.......is it leaking?
    Apr 2004
    Carlingford NSW
    691
    No.. at least they fixed that :)
    Feb 2006
    2,334
    New seals with often be tight at the start. This means that when you lock the group handle in to the group head, it often wont make it past 6 oclock. Dont force it - if it seals, thats all that matters! Over time the seal will start to perish and soften. The group handle will progressively make its way past 6oclock. When it becomes extreme, eg locking in at 5 oclock, its time for new seals.
    Perhaps the person who repaired your machine put in some spacers which may account for the the group handle locking in at 7 oclock.
    Apr 2004
    Carlingford NSW
    691
    Thank you David - that makes sense :)
  1. em6910 collar replacement
    By em6910 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 8th April 2011, 03:55 PM
  2. EM6910 New Collar
    By rich00 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 7th September 2009, 11:33 AM
  3. How to change a collar on a SB EM6910
    By A_M in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 17th February 2009, 06:35 PM
  4. EM6910 collar worn
    By Thundergod in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 21st November 2008, 11:20 AM
