Results 1 to 14 of 14
Thread: HELP NEMOX PROBLEM
    Sep 2008
    249
    HELP NEMOX PROBLEM
    I accidently pulled a shot this morning without the shower screen on (major lack of sleep) :-[ It seems, nothing is happening now, no water is pumping through. Is there anything I can do, or is it cactus?
    Apr 2008
    Brisbane
    5,113
    Re: HELP NEMOX PROBLEM
    Why was the shower screen off?
    Normally it takes a screwdriver to remove it from the group head?
    Sep 2008
    249
    I was doing the backflush yesterday & clean forgot to put it back on. Ive had a horror few days of lack of sleep , the 2yo has had croup :(
    16,762
    Quote Originally Posted by 0E0517020905130E0F02600 link=1269145234/2#2 date=1269146359
    I was doing the backflush yesterday & clean forgot to put it back on. Ive had a horror few days of lack of sleep , the 2yo has had croup *:(
    Poor little bugger.... You too Newbee.... :(
    Have you refitted the shower-screen in the mean time and if so, can you describe in as detailed a fashion as possible, what the symptoms are? This will help us to help you get things up and running again as quickly as possible.
    I spose if youre really desperate though, you could drop your machine off to the vendor you bought it from to have it checked out, or maybe one of our Site Sponsors and explain your dilemma...
    Wish I could offer more advice Newbee but need more info.....
    All the best,
    Sep 2008
    249
    Thanks Mal for getting back to me. I have refitted shower screen & tried - no luck. Ive taken off group head seal & teflon spacer & given them a good clean. The pump sounds as though its about to deliver water & then it just seizes.
    Any thoughts?
    C
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 6E6577626965736E6F62000 link=1269145234/4#4 date=1269178909
    Any thoughts?
    C
    My guess is that you have ground coffee in a solenoid or valve and it will require dissambly to manually clean..
    senior member
    Mar 2008
    Perth
    150
    Is it possible that whilst under pressure the puck has pushed up into the group head causing a blockage? - does the pump sound the same as when you backflush against a blind basket?
    Sep 2008
    249
    Yes, it does, sound similar. However, thats where it stops.............
    Sep 2008
    249
    Quote Originally Posted by 78575E5C4B745857585E5C545C574D390 link=1269145234/5#5 date=1269180320
    I think AM is right, it was a stupid sleep deprived thing to do :-/ :(
    Im guessing that Ill be taking it for a service & major clean asap *:-[
    16,762
    Quote Originally Posted by 616A786D666A7C61606D0F0 link=1269145234/8#8 date=1269181196
    Yep, I think AM is probably on the money as well... And dont be so hard on yourself Newbee, we all need sleep and Ive done waaaayyy sillier things than this because of too little....
    Taking it to a reputable service professional is probably going to be the best way out for you though, especially with a very unhappy littlen demanding most of your time. If you know of any fellow CSers in your neighbourhood who may be able to help you out, that could be another option?
    Anyway mate, all the best to you and your little one.... :)
    Sep 2008
    249
    Thanks Mal. I dont of any fellow CSers who are that handy. Fellow CSers hmmmm??? :)
    14,665
    Quote Originally Posted by 575C4E5B505C4A57565B390 link=1269145234/10#10 date=1269209295
    You might have to take it to your local techie newbie...
    Not a big job, so you shouldnt be too much out of pocket...
    Good luck! ;)
    Mar 2009
    42
    Sounds like coffee has been sucked back up and blocked the pipe to the group. When you turn the pump off, does any water come out of the 3 way solenoid? If no, i think it might need to be disassembled to be fixed. If yes, then you might be able to fix the blockage by sticking a pipecleaner or something through the outlet in the group to try and dislodge the blockage. At worst, you will push coffee into the boiler, so dont push to far or hard, but you should be able to flush it out anyway.
    Just trying to save you a service fee, and Im not too sure if this is even a viable fix. So maybe someone could give some input before you try it.
    Sep 2008
    249
    Quote Originally Posted by 7A253D2B202B272E2E2D2D252926480 link=1269145234/11#11 date=1269210128
    Thanks for your support 2mcm. Its with my local techie, I couldnt be without it. Tetleys just doesnt do it for me in the morning ;D
  1. Ikon+Nemox Lux Crema Problem
    By lilmeh in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 12th July 2011, 08:51 AM
  2. Nemox Dell Opera problem
    By bulge in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 19th February 2010, 12:21 AM
  3. Nemox Del Opera - Group Housing Problem
    By Ardy in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 25th September 2009, 12:37 PM
  4. nemox v anything else
    By Ash25 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 21st February 2009, 09:21 PM
