Results 1 to 26 of 26
Thread: em6910 steam issues
    Mar 2010
    10
    em6910 steam issues
    After a couple of years of faithful service, my em6910 has developed a problem with the steam side of things.
    A colleague filled up the water tank this morning, but i dont think it clicked in properly - i poured a shot which struggled for water but got there + then when I went to use the steam wand, it didnt pressure up properly and is now all but dead. :(
    Symptoms now are:
    steam wand heating but no pressure. (just very weak pumps)
    Group + hot water pump working fine.
    I called SB repair centre + the guy told me it may be any one of 3 problems:
    blocked = $90 - 115
    new circuit board - $270
    or pump - warranty
    is there anyway of knowing what it is before i get taken for a ride at the service centre?
    Thanks in advance, Matt
    Nov 2007
    Lake Macquarie NSW
    113
    Re: em6910 steam issues
    Hi Matt
    There have been a few threads about steam blockages in 6910s. A search would help, just remember to change the default search range to something longer than the default 1 week.
    This may get you started : http://coffeesnobs.com.au/YaBB.pl?num=1232674232
    No doubt some others will contribute also.
    Russell
    Oct 2008
    79
    Quote Originally Posted by 424E5B5B704C2F0 link=1269996384/0#0 date=1269996384
    blocked = $90 - 115
    or pump - warranty
    I have had several EM6900s where the Steam Wand failed...the current EM6910 still working beautifully. While the "reliability" of the EM69xx is debatable, from my experience the Sunbeam support has always been top notch so hopefully, being taken for a ride wont come into the equation.
    Jan 2008
    1,756
    Quote Originally Posted by 2A0D0C0711163D25031803620 link=1269996384/2#2 date=1269999359
    well well, everyday has its "firsts" i have never heard that before :-?
    congratulations :) its good to hear the occasional good story about sunbeam support.
    cheers
    warren
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 1136373C2A2D061E382338590 link=1269996384/2#2 date=1269999359
    blocked = $90 - 115
    or pump - warranty
    Thanks in advance, Matt *
    I have had several EM6900s where the Steam Wand failed...the current EM6910 still working beautifully. *While the "reliability" of the EM69xx is debatable, from my experience the Sunbeam support has always been top notch so hopefully, being taken for a ride wont come into the equation.
    If you ever fully choke an EM6910 and keep pushing it OR use a true Blind filter you can and will blow the steam pump.
    Note there is a fix for this... But it is a work around; that being said... I did it to mine and happy.
    Some time in teh next week I hope to have a post up as to mods to the EM69xx series; that will enhance reliability for both units but more so for the 6910 - Steam and group..
    enjoy black coffee JamesM's Avatar
    Nov 2008
    Perth
    672
    AM, looking forward to your posts.. also perhaps some pros/cons of re-programming an EM6910 (steam and brew variables, etc)
    James
    Mar 2010
    10
    A simple back flush seems to have fixed the problem, so all good.
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 153E323A2C125F0 link=1269996384/5#5 date=1270009609
    James
    Yea should not be too far away.
    Quote Originally Posted by 323E2B2B003C5F0 link=1269996384/6#6 date=1270013104
    Not fixed by solved the intimidate cause... Grinds in the lines.
    If ya not careful..... Dead pump system.
    SB are now identifying the issue of a FAILED Coil Vs User generated... Art some stage they will fix or just put back on the user..
    Idiocracy in the wings...
    Mar 2010
    10
    OK, so what do you suggest as a longer term solution? How do I clean / avoid "grinds in the line"?
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 2B2732321925460 link=1269996384/8#8 date=1270020887
    OK, so what do you suggest as a longer term solution? *How do I clean / *avoid "grinds in the line"?
    Search and follow the directions that have been posted time and time again.
    1: Do not OVERdose... 5 cent test
    2: Regular maintenance and Depending upon usage:
    A: - Short manual run or two with teh rubber blind at the end of the day ??.
    B: - Correct chemical back flush and cleaning of the shower screen etc every 3 weeks ????
    C. - Good water - Filtered is not filtered
    3: Purge ya steam b4 and after using
    4: After ya dump ya puck... place group in lightly - hit manual and wiggle a bit [smiley=2vrolijk_08.gif]
    5: Do not over lock or force the group in = OVERDOSE
    6: Keep ya group seal in good condition.
    And the list can go on.. Do some searching and spend the time to read...
    Mar 2010
    10
    Excellent tips - thanks! so far I have only been doing about half of what you suggest.....
    1. I am not sure what the 5c test is, but I will do a bit of searching around.
    2.
    a. Short manual run sounds like a good idea.
    b. back flush regularly. yep
    c. water could be better for sure
    3. yep
    4. I normally run manual without group in + rinse the group, but i will try the wiggle!
    5. yep
    6. yep
    Mar 2010
    10
    Looks like is was indeed a temporary fix, as the blockage has returned. :(
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 333F2A2A013D5E0 link=1269996384/11#11 date=1270099332
    Looks like is was indeed a temporary fix, as the blockage has returned. *:(
    Sounds like you have got grinds in the system...
    That means a pull down and clean out... Try SB for a Warranty Pump job ??
    Where are you located ?
    Mar 2010
    10
    sounds like it....
    Im in Sydney - closest service centre is Ashfield.
    After talking to them last week, it sounds like they will only cover it if its the pump and nothing but the pump. If its blocked they will likely charge me.
    I could attempt pull down + clean out - I am reasonably handy with stuff like that + see quite a few posts on how to do it...
    Mar 2010
    10
    btw, I have no pressure at all coming through the wand now.
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 5B5742426955360 link=1269996384/14#14 date=1270103130
    Does the pump sound likes it working ... If not working then the switch OR the coil.
    Being handy BUT working around and with 240V parts is not legal NOR safe !!!
    Assumptions kill people.
    Mar 2010
    10
    yep its doing something.
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 737F6A6A417D1E0 link=1269996384/16#16 date=1270103377
    Scale and or grinds in teh system..
    Thus would need to be stripped / fully cleaned with a REAL de-scaler / Solenoids pulled down and cleaned and then it may work..
    I am looking for DEAD units; see my other post WTB ;)
    Mar 2010
    10
    true, but it wouldnt be the first time i have attempted such an activity.
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 494550507B47240 link=1269996384/18#18 date=1270103550
    True..
    If thats your intent... Do your research, as Matrix ? etc and others have many posts as to Last ditched attempt to clean steam wand etc etc and plenty of pics.
    Some have also admitted to getting into trouble...
    Could also be a Last...
    STAY SAFE... DISCONNECT .... Do the Work and then get some one else to check.
    Mar 2010
    10
    thanks - easter project coming up.
    Senior Member clubbi4's Avatar
    Feb 2008
    110
    Im wondering how fully choking the brew pump effects the steam pump??? :-? :-? :-? :-? :-?
    They are 2 seperate pumps...
  23. #23
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 505F4651515A07330 link=1269996384/21#21 date=1270162725
    SO.... *Ever think they might be connected ? *And if so how and what components may be in between.. *Does every one truly understand how a vib pump works and or the configuration that the manufacturer might use.
    Ever worked with SSRs... I have seen then wired almost back-to front and linked input to out put *:o :o :o Does not make sense... *But some one much smarter than me figured out a neat way of using it for a smart outcome...
    Programming and un documented features... Allows some to do things the average coder would never consider.
    Assumptions is what gets people into trouble...
    How long have I been pulling EM6910 and others system apart.. *Do I know them 100% back to front NO.. * I learn every day.
    Can I explain in 5 min ... NO... It involves valves, OP systems and a FAULT condition to develop and presto the guts of ya vibe pump get coffee fines in it and stuff it. *YES the SB repair agent can see this.
    Should it happen NO... But if you do things incorrectly; then no manufacturer can cover off on PEBFAG.
    My car has good breaks... *But if speeding in wet wet weather and come to a T junction and only apply the breaks 10M out... Will my car stop in time - NO. *Manufacturer or *Driver ?
    Yea.. Today the thought is Manufacturer. Idoriacy *;)
    Enjoy the coffee road.. It can get bumpy...
    PS. Dont take it personal. Some days are better than others for me.. Depends on Coffee and Meds *;D :o *8-)
  24. #24
    Feb 2008
    110
  25. #25
    DONT USE
    Jan 2008
    432
    good question clubbie
  26. #26
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 303F2E560 link=1269996384/24#24 date=1270631161
    Im wondering how fully choking the brew pump effects the steam pump??? * *
    See here http://coffeesnobs.com.au/YaBB.pl?num=1270540936/4#4
    And not the full story and all the minute detail is not covered.
    But many people assume and you know what that does.
    Any one ever fully studied the flow diag and asked what if this failed and or this got stuck ?
    The hard one is "What will happen when a member of the public uses it " - And guess what NO one can answer that other than *"they will stuff it" nothing is ever user/ 1d10t proof.
  1. Sunbeam EM6910 issues
    By aussiedean in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 22nd July 2015, 07:15 PM
  2. Please help: Gaggia Evolution steam issues
    By ryanwong5601 in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 9th October 2012, 07:08 PM
  3. 6910 steam wand issues
    By evergreen in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 4th October 2011, 09:32 AM
