Results 1 to 4 of 4
Thread: EM6910 lock position
    Sep 2007
    19
    I bought an EM6910 12 days ago. For the first week the group handle was locking in the 6 oclock position but now it locks off at about 5 oclock. I phoned Sunbeam this morning and they said it is normal for new machines to lock off at different positions but the manual says that this will happen after the seal becomes worn.
    Have others found this with their new machines ?
    Thx.
    Jun 2009
    214
    Re: EM6910 lock position
    Hey codlocks,
    This is not uncommon with SB 6910. Its totally normal as long as its sealing properly during extraction. Has also been talked a lot on here use the search function (3rd tab from the top left of the screen) it will be your best friend. Make sure you change the default from "week" to "All" and away you go my friend. 8-)
    DONT USE
    Jan 2008
    432
    hi
    on the front face of the machine, just above the handle, there is an arrow, approx 5,:30
    good guide as to lock in position
    the silicone seal will soften with use and heat
    graham
    Sep 2007
    19
    Thanks ANU - I did scroll page-by-page through quite a few posts initially. Sounds reasonably common so I wont worry.
    Graham - thanks, thats exactly where it points to.
  1. EM6910 - Replaced group head lock, now machine pumps water when AC is switched on
    By freaky-namuh in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 11th August 2009, 04:36 PM
  2. Help.. Air Lock?
    By Hooked in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 14th February 2009, 09:19 PM
  3. [m]: Position in DiBartoli
    By Dimal in forum General Coffee Related...
    Last Post: 10th July 2008, 10:43 AM
