Results 1 to 5 of 5
Thread: EM6900 Programming
    A_M
    A_M is offline
    Mar 2006
    6,381
    EM6900 Programming
    Ok all you current and x EM6900 users..
    I am looking for info as the the advanced programming steps.
    Assumed.... Yea it got me ;D
    That the EM6910 and EM6900 would be the same / very close...
    Of the two boxes of parts that I have obtained from a recent request for dead units etc I am observing different things. But have no SB EM6900 user manual... The Links on the SB site no longer exist and need to confirm / refute my assumptions...
    Then I can be sure as to FAULTY controller board or NOT.
    10,496
    Re: EM6900 Programming
    IIRC there were no advanced programming options on the original 6900s.
    A few late models and refurbs had 6910 internals and they had 6910 internals with the options.
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 714D504B414057424A41250 link=1270768890/1#1 date=1270769793
    Arr I though as much.... THANK YOU.
    Used one at work some time ago and it did have... But the couple I have here do not appear to..
    PS. How is the dryer ?
    Did ya see the post http://coffeesnobs.com.au/YaBB.pl?num=1265274280/4#4
    What was ya findings ???
    10,496
    Ill have a read.
    When testing the element core to sheath I get the same reading as when the probes are not touching anything.
    It looks like an error code or similar as it doesnt mean anything to me and I have to find the instruction book to check its meaning.
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 6E524F545E5F485D555E3A0 link=1270768890/3#3 date=1270799832
    That is GOOD...
    Not a true test... But good.
    Some might say why not 100%. The issue is that the usual test with a multimeter is at low voltage and potential... Thus a meter with a a tenth (0.10) of a mm gap will show OPEN cct. Yet a 680v (240Rms) may well have the potential to cross that air gap.. Add a bit of moisture and carbon dust and the normal meter might say 300meg.. Apply a megga and it might test as good as a SHORT.
    That is why mega testers usually have a 250 / 500 and 1000 v test ranges to ensure that the insulation resistance; is true and realistic.
    And yes, I have on the odd occasion measured and found OC with a normal meter and then smoked the unit when turning it on... Dont take chances any more.
  1. Programming Klub N2 button pad
    By bassway in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 22nd October 2018, 04:19 PM
  2. Change programming
    By becster54 in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 23rd November 2011, 11:47 AM
  3. Help with Silvia 935 timer programming
    By coffee4avi in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 23rd July 2011, 04:29 PM
