Results 1 to 3 of 3
Thread: Silva has a problem- pump?
    Dec 2008
    10
    I made coffee this morning, no problem. Topped up water and tried to make coffee at lunchtime. Instead of the deep rumble from the pump and a good trick of coffee into the cup there was a much softer noise and only a few drips came through and a lot of steam as well. It seems to be much hotter than normal If I tried the water outlet, only steam comes out.
    The machnie is about 15 months old.
    Mar 2010
    14
    Re: Silva has a problem- pump?
    What comes out when you turn the brew switch on without the group handle attached.
    Could be that somethings blocking the water. Have you ever descaled the machine. If this is the case and water aint being sent to the boiler you might burn the element so be careful when testing.
    Just my 2 cents.
    Jul 2008
    Port Fairy
    2,993
    Dont run it again !!!! Your boiler is out of water and you will burn out the element *:(
    Next bit depends on how handy you are or not but sounds like your pump is dead or there is a blockage in it or in the pipes going to your boiler. If you are not to handy and have one of the sponsors nearby then take Silvia for a trip I reckon.
  1. Problem with Watlow96 and pump preasure
    By gab9479 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 4th September 2012, 09:51 AM
  2. Rancilio Ms Silva Problem
    By mashman in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 15th August 2010, 07:48 AM
  3. Replies: 0
    Last Post: 14th August 2010, 07:04 PM
  4. ecm giotto - pump problem
    By lisa_i in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 11th February 2008, 09:31 PM
