Results 1 to 17 of 17
Thread: EM6910 problem
    May 2009
    42
    EM6910 problem
    My EM6910 is not pumping water through... the steam starts off ok then cuts off into little splurts of steam. Is this a water tank issue or something greater i.e. pump?
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: EM6910 problem
    Quote Originally Posted by 70787172731D0 link=1273192330/0#0 date=1273192330
    Search CS and use the advance search function. All been talked about as well as a number of possible fixes.
    Sounds like you have got some crap in ya system... Be is scale and or coffee fines from Overdosing and Choking the system.
    1: How old is it ?
    2: How often do you follow the correct cleaning methods etc
    May 2009
    42
    Re: EM6910 problem
    Thanks for the reply.
    I bought the machine end of 2007... so it is a little over 2 years old.
    I do the correct cleaning methods approx every 6 months... I did it only a month ago. It was working fine a few weeks ago, I recently brought the machine back up to where I live now from my parents and set it up this morning... not working.
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: EM6910 problem
    Quote Originally Posted by 454D444746280 link=1273192330/2#2 date=1273193571
    How is teh hot water ?
    How is it with just a manual run through teh head
    Could be that teh water tank is not seated correctly and or has a small air lock.
    Prime a few times.
    May 2009
    42
    Re: EM6910 problem
    I reseated the water tank a few times... I only tried it with manual.
    10,496
    Re: EM6910 problem
    Quote Originally Posted by 48676E6C7B446867686E6C646C677D090 link=1273192330/3#3 date=1273194091
    How is it with just a manual run through the head
    Just to be sure, I think he meant no basket, just press manual button, does water come through the head?
    And does water come out of the hot water spout?
    May 2009
    42
    Re: EM6910 problem
    water doesnt come through the head in general, every now and again a few drops might come through. It dribbles through the hot water spout, the steam wand starts up a bit then drops out as well.
    Apr 2008
    370
    Re: EM6910 problem
    Have you taken out the showerscreen and gasket before? I suspect it may be clogged with grounds, especially if you are overdosing.
    May 2009
    42
    Re: EM6910 problem
    Ill try that tomorrow... the problem is that the steam wand and water spout have issues too. They work for about the first 2 seconds and then die out... Ill try and post a video tomorrow.
    There doesnt seem to be a technician nearby so I dont really want to have to deal with Sunbeam.
    May 2009
    42
    Re: EM6910 problem
    I tried to use the single and double shot buttons... the machine makes the start up noise then stops and all the lights on the buttons go back to standby mode (all on).
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: EM6910 problem
    Quote Originally Posted by 2A222B2829470 link=1273192330/9#9 date=1273309745
    I tried to use the single and double shot buttons... the machine makes the start up noise then stops and all the lights on the buttons go back to standby mode (all on). *
    1: Make sure ya tank is full and fitted correctly..
    2: Do a factory reset and then get back to us with the outcome
    PS. Where are ya located.
    Steam and hot water issues imply the main solenoid and or between that and the Tank...
    May 2009
    42
    Re: EM6910 problem
    Tank is fine. Im located in SYD .. Eastern Suburbs. According to Sunbeam, the closest is Bondi Junction but they dont do coffee repairs. Next would be Ashfield, but thats over 30mins from here.
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: EM6910 problem
    Quote Originally Posted by 2F272E2D2C420 link=1273192330/11#11 date=1273390033
    Did ya do a factory reset ?
    Is it under warranty ?
    If under warranty... Ya got no choice... If not, then it will be interesting as with no ability to get hands on.. Can not help any further.
    May 2009
    42
    Re: EM6910 problem
    I just did one then... didnt help. Its out of warranty, but the pump is still under warranty if it is a pump issue. Im just uploading a vid, sounds like something might be loose inside.
    May 2009
    42
    Re: EM6910 problem
    video is at: http://www.youtube.com/watch?v=DzlIvVd1z6Q
    Jun 2009
    214
    Re: EM6910 problem
    Hi Melon,
    Sounds like something is blocking the water from coming out. When did you last properly descale it( following instructions from the manual) and what did you use? i.e. Sunbeam tablets or some liquid solution.
    Also have you ever changed the anti-calc filter? :-?
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: EM6910 problem
    Ya got a blockage some where..
    Two seperate pumps... They sound OK..
    In the first instance.... NOT warranty..
    Ya said it was working and then you transported and now not working..
    Suggest scale / coffee grinds and or the checkvalve / tank fitting.
  1. EM6910 problem...
    By rooeey in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 3rd June 2012, 08:00 AM
  2. EM6910 blockage problem
    By loppyfo in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 15th November 2009, 05:01 PM
  3. My Brand new EM6910 ?problem
    By coffeenator in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 11th May 2009, 05:37 AM
  4. Em6910 problem
    By mmmcoffee in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 9th May 2009, 10:58 AM
