Results 1 to 13 of 13
Thread: EM6910 Issue
    May 2010
    1
    EM6910 Issue
    Hey guys, long time lurker, first time poster here.
    Had an EM6910 for a while. Never had a problem with it, and can always get nice tiger stripes.
    Was running descaler through it with a blind head, and for whatever reason the pressue didnt "dump" at the end of the cycle like it normally does. Now the portafilter is jammed onto te group head nice and tight.
    Im pretty sure if I try any harder to wrench it off Ill risk breaking the machine with torque. Any suggestions?
    Thanks in advance!
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: EM6910 Issue
    Never ever use a blind filter.
    Say again Never. *Read the manual and use the Rubber blind.. (edited - damad i-phone)
    Open the hot water ....
    A little wiggle and hope.
    Would suggest that you may have stufed it, if any grinds got back into the system. Valve / Gauge and Steam will now be suspect.
    Caffeine Junky
    May 2009
    1,103
    Re: EM6910 Issue
    Quote Originally Posted by 3E3020232637530 link=1273908439/0#0 date=1273908439
    I hope you meant to say detergent?
    Mar 2010
    28
    Re: EM6910 Issue
    Just on this topic, dont mean to thread-jack or anything, but does the EM6910 not have a 3-way valve that allows for backflushing with a blind filter?
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: EM6910 Issue
    Quote Originally Posted by 332B2E7978410 link=1273908439/3#3 date=1273968486
    NO
    Some might argue... The actual valve used is in-fact a 3 way... However the configuration of this valve is such that it does not perform the same FUNCTION and nor in the same manner as other systems. Some system have many 3-way valves in use...
    Further more; teh use of teh term 3-way is misleading in the context that many in the coffee world reference it/ and its true functionality should actually be termed ie... as an isolated group dump valve OR group back pressure isolation valve OR
    Any taker for something a little more 100% correct
    1: Plumbing but be a isolated cct
    2: Focused on teh Group
    3: Manual or electronic
    4:
    5:
    Oppps 10.100
    Mar 2010
    28
    Re: EM6910 Issue
    Fair enough. Always good to have a better understanding as to what actually operates inside these things!! Are there many machines on the market nowadays (bar Sunbeam/Breville) that dont include these valves?
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: EM6910 Issue
    Quote Originally Posted by 233B3E6968510 link=1273908439/5#5 date=1273996450
    Fair enough.
    No... Most every device uses a 3 way of sorts some where in their system...
    But as to employing a an isolated group dump valve OR group back pressure isolation valve OR other... methods to perform the same function...
    Who knows...
    How many machines out there to start with :D
    May 2010
    1
    Café Series® Espresso Machine problems
    hi guys i just got given a Café Series Espresso Machine
    EM6910 and i gave it a try tonight but when i switch it on it makes a buzzing sound and does not steam up or release any water it is missing the twisty bit the coffee goes in which we are trying to replace if any of us know the problem could you please send me an email telling me how to fix it or where to get it fixed cheers guys
    14,665
    Re: EM6910 Issue
    Id suggest you try a Sunbeam service centre
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: EM6910 Issue
    Quote Originally Posted by 3031363038656A3621530 link=1273908439/7#7 date=1274094892
    One... What is YA location..
    TWO ... Download the manual and do some reading..
    "It is missing the twisty bit" *I had a laugh... Sorry... Heard lots of descriptions but that takes the cake..
    Sounds like it was given to you for a reason... It has problems...
    AND agree with the following,
    Quote Originally Posted by 613E26303B303C353536363E323D530 link=1273908439/8#8 date=1274095500
    In addition; A visit to ya local CS sponsor to learn more may be a much better way froward than continuing with the EM6910.
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: EM6910 Issue
    Quote Originally Posted by 595747444150340 link=1273908439/0#0 date=1273908439
    Had an EM6910 for a while. *Never had a problem with it, and can always get nice tiger stripes.
    Was running descaler through it with a blind head, and for whatever reason the pressue didnt "dump" at the end of the cycle like it normally does. *Now the portafilter is jammed onto te group head nice and tight.
    Im pretty sure if I try any harder to wrench it off Ill risk breaking the machine with torque. *Any suggestions?
    Thanks in advance!
    Any updates or a hit and run post ?
    10,496
    Re: EM6910 Issue
    Quote Originally Posted by 5D5343404554300 link=1273908439/0#0 date=1273908439
    Thanks in advance!
    Happened to me once.
    You need to break the pressure seal.
    Try levering the edge of the basket VERY carefully with a stubby screwdriver.
    Dont aim to release all the pressure in one go.
    If you manage to release a little then back off and try again to release a little more.
    Once youve relieved all the pressure it should come off as normal.
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: EM6910 Issue
    No group or baskets and makes buzzing noises..
    I think I know why they gave it away..
    Realy not worth taking on others failures, unless your across the machine... Be it a Car, Coffee machine or boat ;)
  1. Yet another Sunbeam em6910 issue
    By tony8028 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 24th March 2011, 03:03 PM
  2. Sunbeam EM6910 Warranty Issue
    By Nick1973 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 13th November 2010, 10:34 AM
  3. EM6910 Drip tray issue.
    By adix in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 2nd November 2008, 09:14 PM
