Results 1 to 4 of 4
Thread: Using cafetto with SB 6910
    Jun 2009
    214
    Hi guys,
    I was wondering is it safe to use a bit of cafetto espresso clean to do the backflush cycle on the sunbeam 6910? Does anyone find the SB tablest do a better job or are they the same?
    thanks guys. :P
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: Using cafetto with SB 6910
    Quote Originally Posted by 2728333F27222730460 link=1276332538/0#0 date=1276332538
    Hi guys,
    thanks guys. :P
    Done and dusted many times..
    1/4 tea spoon.. Is fine - Only way to go.
    Just do teh cleaning cycly / back flush prog as Sunbeam recommend... And then a few plain water shots to give a an extra flush (use teh rubber blind)
    Jan 2010
    59
    I use it, no probs, its really good to soak all your coffee equipment in :)
    Aug 2007
    101
    yup, I third those sentiments. I do a full 2nd backflush cycle with plain water after the cafetto. Cafetto rocks, cleans so, so well. If only there was the human equivalent that you good backflush your body with. :D
  1. Has cafetto ruined my 6910 ?
    By derrilex in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 27th July 2010, 07:21 PM
  2. Cafetto
    By anuyadav in forum General Coffee Related...
    Last Post: 16th May 2010, 11:38 AM
