Results 1 to 10 of 10
Thread: 2009 Rancilio Silvia - backflushing? yes? not? how to step by step?
    Apr 2010
    155
    hello, apologies if this has been covered elsewhere (a pointer please?)
    I have a 2009 (latest model) Silvia. Do I need to backflush it? how often? and if so please provide step by step instructions, I would hate to destroy the new $800+ machine! 8^)
    thank you in advance
    Apr 2008
    Brisbane
    5,117
    Re: 2009 Rancilio Silvia - backflushing? yes? not? how to step by step?
    This should have been covered from the place you purchased it from
    In general
    If an espresso machine has a 3 way valve you can back flush by using the blind filter
    1] water only daily
    2] with chemical after 1 kg of beans
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 092D242427271D092D312F2D420 link=1277532170/1#1 date=1277532388
    Fully agree..
    Tis a shame people buy and then have to go to a public forum to find out the basics..
    Do some reading here.. http://home.surewest.net/frcn/Coffee/Coffee.html
    All good stuff and plenty of Silvia information..
    Shame teh supplier did not point you in that direction.
    Mar 2010
    Brisbane
    56
    Hi Acid Rider,
    Ive also got a Silvia (08 model), which I bought second hand from a CS member who also gave me operating and maintenance instructions for the silvia from a reliable CS sponsor.
    Have just re-read the Silvia instruction booklet which as youve probably noticed does not mention anything about backflushing the machine at all. *The notes I have from the site sponsor state that [u]chemical[u] backflushing should not be performed while it is under warranty (12 months) as this may void your warranty (nothing is mentioned in the silvia instruction manual about this however). *
    However as KK mentioned backflushing with water only should be done daily, presuming you have used the machine daily, and with chemical fortnightly or after ~1kg of coffee (if you choose to wait for 12 months).
    The site sponsor explains how to backflush as:
    : Insert blind filter into handle and lock into place in group head
    : Press coffee button and let it run for five seconds, remove handle and empty dirty water
    : Repeat above process five times
    : Replace normal filter into handle and empty your driptray
    When you choose to do a chemical backflush (using something like clean machine)
    : Place teaspoon full *of backflush powder in blind filter and lock into group head
    : Press coffee button and let run for five seconds (dont remove and empty handle after each backflush)
    : Repeat five times
    : Remove handle and clean any leftover powder from blind filter
    : Backflush using water as previously explained five times
    You may want to discard your first shot after this chemical process to ensure no chemical taste in your shot.
    Hope you find this helpful.
    Paul
    14,665
    The Silvia has a 3 way valve and is designed to be backflushed.
    Backflush it regularly- regardless of what the seller says ::)
    10,496
    Quote Originally Posted by 2027363A3D2A666666530 link=1277532170/3#3 date=1277535238
    A year without cleaning?
    Sounds a bit extreme.
    Dec 2006
    Perth WA
    572
    Just a quick suggested addition to Pauls instructions:
    "When you choose to do a chemical backflush (using something like clean machine)
    Addition:
    Then let the flushing chemical sit in the machine for say 15 seconds before you repeat
    : Repeat five times
    : Backflush using water as previously explained five times"
    Explanation this gives the detergent time to melt the old coffee sludge before it is flushed away. *I have done this and the wait certainly adds a lot of residue. *I may be in error - if so I am happy *to be corrected.
    D
    14,665
    Quote Originally Posted by 65746C687860010 link=1277532170/6#6 date=1277541039
    Much too much for a domestic machine dumiya. I suggest more like 1/3 teaspoon...
    2mcm
    Dec 2006
    Perth WA
    572
    2mcm
    I agree I missed seeing that amount in the original post
    D
    Apr 2010
    155
    thanks everyone. will check it out. yes, i read the instructions and this is what confused me. the shop did give me the blind filter and even some power for backflushing but given i was confused in printed instructions verus what the shop said - i decided to ask here.....
    now i have more details i can move on....
    the warranty on 2009 silvia, i believe, is now 2 years, i dont really want to risk it.
  1. Step by Step Guide - Install PID in a Silvia.
    By WSullivan in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 29th October 2013, 03:27 PM
  2. DIY Step by Step guide - Silvia Boiler Element Replacement
    By digitalcoffee in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 8th February 2011, 10:08 PM
  3. How to PID a Rancilio Silvia - A Step by Step Guide
    Last Post: 1st July 2009, 04:45 PM
