Results 1 to 14 of 14
Thread: Upgradeitis - Sunbeam em3600 --> ???
    Jul 2008
    11
    Hi All,
    Been a long time lurker here and ive taken many a great tip. I have an EM3600 and a sunbeam grinder EM0450, i moved around the corner from Coffee alchemy and have been buying beans that have been roasted either same day or the day after, previously i was using a different but locally roasted bean, probably a week or two from roast date and my crema is dissipating before i pour my milk, i did reduce my grind size and tamp less in a effort to let the fresh coffee apply more back pressure, is this right?? The coffee tastes great but id prefer a better crema, i have an unpressurised krups basket coming in the mail as we speak, but a solution now would be nice.
    Or is the solution an upgrade? The Silvias seem to be getting a pretty great rap, what should i expect to pay? Ive seen some second handers on evilbay for around $400ish. will my grinder still stand up?
    Im in Enmore, Sydney.
    thanks in advance
    10,496
    Re: Upgradeitis - Sunbeam em3600 --> ???
    The EM0450 should be OK.
    Quote Originally Posted by 426C67676A666A7760050 link=1278555535/0#0 date=1278555535
    Unless you grind extremely fine, the pressure is dictated by the pressurised basket I assume youre currently using.
    And at that level of fineness you may just put too much pressure on the system.
    Best to wait for the new basket.
    Quote Originally Posted by 48666D6D606C607D6A0F0 link=1278555535/0#0 date=1278555535
    Im a firm believer that when it comes to coffee machines, unless you can see it working you should steer clear of the Bay of Evils.
    Senior Member Stan's Avatar
    Dec 2007
    Just North of Brisbane
    948
    Be aware you are starting on a slippery slope of upgraditis. *Silvia is a great machine as stated by many owners (I personally have never owned one). *The Em0450 will probably be alright but as stated in many previous posts here - spend the money on a good grinder and benefits will flow. *I started with an EM4800c and 0480 and got good coffee. *I bought a Mazzer Mini whilst I still had the Em4800c and got better coffee. *I then bought an EM6910 as a stop gap until I can afford a better machine. *So in a few words buy a better grinder first *;)
    TG is correct, he was writing as was I and he posted first. *The unpressurised basket (with practice) will improve your coffee. *I used one on the 4800C and found it improved. *Then I bought the Mazzer and found a greater improvement. *but as stated the upgraditis but has bitten. *:D
    Jul 2008
    11
    Cheers fellas.
    Makes sense.
    Upon further reading the lelite combo is looking pretty damned good.
    Jul 2010
    Sydney's Northern Beaches
    148
    Quote Originally Posted by 1C323939343834293E5B0 link=1278555535/3#3 date=1278564036
    Cheers fellas.
    Makes sense.
    Im preordering a lelit machine as I dont already have a grinder and didnt want to have yet another machine/appliance on the counter. I chose the Lelit because i know the grinder will match the espresso machine well. And also because of its great performance for price. Theres some good reviews on coffeegeek.com . Also if youre looking to save a little try the Lelit PL041 - same as the $850 combi but without the grinder. Its cheaper then the silvia and can produce coffee just as good.
    Cons = 57mm protafilter (wont really matter unless you suddenly become a modding nut) and that its hard to find.
    good luck.
    Jun 2010
    216
    I have read the latest model lelit PL041QE has some improvements, new shower head, steam wand, and opv has been reduced to 9 bar instead of 15bar , has caused some issue with users of old machine , as low pump pressure wont flow throw same grind as before.
    not sure if combi has same improvements i suspect it would.
    First off, and most obvious is the relocation of the steam knob. This is to provide a more natural feel and use for the machine.
    Second, is the steam wand, now standard is the non-frothing aid wand, which was introduced on the 2010 model earlier this year.
    Third, and most important is the dispersion screen found in the group. Lelit has redesigned this part, using a new screen and jet to ensure OPTIMAL water flow through your espresso puck. This also allows the use of a newly added pod basket.
    mod edit to meet site posting policy
    Jul 2010
    148
    Quote Originally Posted by 07283324312E362433410 link=1278555535/5#5 date=1278642529
    I have read the latest model lelit has some improvements, new shower head, steam wand, and opv has been reduced to 9 bar instead of 15bar
    Where did you read or hear this information? Sounds good to me. Any pictures around of the new setup with the relocated knob and steam wand? Is the new one on a ball-socket ??!!!
    Jun 2010
    216
    This is the Lelit PL041QE
    The first second and third points above are quoted from website
    cant post link but do google on
    LeLit Espresso, Cappuccino, & Coffee Center
    I liking lelit with built in grinder, looks very classy.
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 6A455E495C435B495E2C0 link=1278555535/7#7 date=1278668206
    LeLit Espresso,
    Coffee Snobs Sponsor is selling and supporting...
    Link all ya want to Jetblack Espresso
    Quote Originally Posted by 38213F3123352639636565540 link=1278555535/6#6 date=1278667517
    Read all about it here.. http://coffeesnobs.com.au/YaBB.pl?num=1211848740/8#8
    Forget the other marketing...
    Jun 2010
    216
    I was only refering to the upgraded Lelit PL041QE, have added model number to posts to avoid confusing.
    I dont care for marketing but i do for a seller who list in detail what they think is good and explains their reasons why and answers customers questions honestly and offers advice. Being an USA website the cost of freight would be horrendous and most dont ship outside of USA anyway. Just sharing with an fellow CS info that might help his purchase decision.
    From some of the posts here some members have been let down by Australian importers, seem the bigger and more open market in the USA offers more competition and better service. I am not referring to any CS sponsors.
    Jul 2010
    148
    Quote Originally Posted by 1E31383A2D123E313E383A323A312B5F0 link=1278555535/8#8 date=1278672183
    Wow thanks so much for this link! This store is so close to where I live!
    Jun 2010
    216
    Your so lucky, not many store that sell machines and accesories here in Brisbane :(, Glad you have one nearby. :)
    Jul 2010
    148
    Quote Originally Posted by 446B7067726D756770020 link=1278555535/11#11 date=1278680085
    Your so lucky, not many store that sell machines and accesories here in Brisbane , Glad you have one nearby.
    Ill be going to the restaurant across the street on Monday for dinner so ill pop in there to have a look - which happens to be my birthday... present to myself? I think so..
    Jul 2010
    148
    Placed a deposit on the machine.
    Do you think its possible to ask the girls/guys there if they can do some sort of package deal / price on the machine, tamper and maybe some descaling solution or even beans?
    ~$900.
  1. !!!GONE!!! - Sunbeam EM3600
    By carazeee in forum Paid Forward - Taken
    Last Post: 1st June 2011, 07:02 PM
  2. GONE: Sunbeam EM3600 - used once!
    By coffeeee in forum SOLD
    Last Post: 14th September 2009, 03:45 PM
  3. Problem with Sunbeam EM3600
    By markso in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 7th July 2009, 07:42 AM
  4. Getting a Sunbeam EM3600 right
    By Kes in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 6th March 2008, 09:37 AM
