Results 1 to 4 of 4
Thread: Silva portafilter water leaking and it does not tighten correctly
    Dec 2008
    10
    gday
    I have a Silva version 2 and the portafilter only seems to close a 1/8 -1/6 turn even if I put a fair bit of force into closing. Water now drips constantly when in use and sometimes unless I really close to with a lot of force the portafilter will start to unlossen during use. You can see it undo. Today it fell out when my wife installed it as was making the coffee.
    I would say that it closes to 7pm position
    Is there a seal that I need to replace. It is about 15 months old and never used to be a problem
    Thanks for any information?
    Kevin
    Aug 2008
    37
    Re: Silva portafilter water leaking and it does not tighten correctly
    Hi Kevin
    Follow this link, it should take you to the Coffee Parts website (they have lots of neat stuff)
    http://www.coffeeparts.com/rancilio/700151.htm
    $4.75 + gst + postage & your leakage should become history!
    David
    Apr 2010
    110
    hey Kevin,
    yeah seems like you might need to take out the gasket and give it a good clean and place a new one in.
    i had a similar problem my my 2nd hand silvia that i bought from a fellow CSer and he did get a new boiler / gasket put in and it still leaked. but by really really tightening it, to maybe around 5 o clock (it went that far with mine but it may vary. it helped stop the leak.
    it still leaks sometimes if i dont tighten it to the max, so one of these days i might try and change the gasket again.
    but anyway i found a website that gave a couple of ideas and photos on how to open it, by screwing a couple of screws on the gasket and pulling it out by pliers. more details on coffeecos website on the october 2006 newsletter.
    hope that helps
    albert
    Dec 2008
    10
    Thanks for the information David and Albert, I have ordered two new gaskets
  1. Water leaking around sides of PF
    By scott_p in forum Brewing Equipment (non-machine specific)
    Last Post: 26th June 2010, 09:15 AM
  2. Portafilter leaking
    By cc2 in forum General Coffee Related...
    Last Post: 17th April 2009, 09:57 AM
  3. Leaking around portafilter
    By Calvin in forum Brewing Equipment (non-machine specific)
    Last Post: 21st December 2007, 07:22 PM
  4. [m]: Leaking around portafilter
    By Dimal in forum General Coffee Related...
    Last Post: 17th December 2007, 09:46 AM
