Results 1 to 3 of 3
Thread: La Pavoni Espresso Plus - repair?
    Dec 2010
    2
    Hi all
    Ive inherited a Pavoni EP (1999 model), and though the steam works the water pump appears dead - theres no water coming through the plunger, and no pump noise happening. I was searching online and found a small repair place near me in East Brunswick but unhappily did not save the address! Could anyone offer a place I could get the machine assessed without big time expenditure? It looks in great condition by the way and I think its worth a little investigation. Its my (potentially) first coffee machine - its been stovetop till now.
    Aug 2010
    63
    Re: La Pavoni Espresso Plus - repair?
    STOP USING THE STEAM.
    It is a single boiler/dual purpose machine with a non-automatic refilling boiler. If the pump isnt working, you are killing the heating element because there is not enough water in the boiler... Search "single boiler priming" - you will need to do this if you get the machine running.
    If you are able to change a light bulb, you can change the pump yourself. Pull it out, find the part number, google it and buy one. Will probably cost you $50 and 10 minutes. If you cant change a light bulb, dont attempt this because you will might get electrocuted.
    Dec 2010
    2
    Thanks so much. Yes I thought it best not to damage the element by running it without water on it. Hopefully its still okay. I will follow up your advice and replace the pump if necessary. Thanks again.
  1. Espresso machine repair in Brisbane?
    By Noel in forum General Coffee Related...
    Last Post: 7th June 2012, 12:58 PM
  2. espresso machine repair
    By lorettac1 in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 3rd March 2012, 09:22 AM
  3. Espresso Shot... La Pavoni ?
    By bambino in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 30th April 2009, 10:17 PM
  4. La Pavoni - manual espresso
    By Rolley in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 17th February 2007, 11:05 PM
