Results 1 to 3 of 3
Thread: Silvia - is my brew switch on the way out? If not, what is?
    Nov 2005
    52
    A few times over the last couple of days, Ive turned on Silvias brew switch and nothing happened (no light, no pumping). Flipping the brew switch off and on again once or twice brought it back to life. Im guessing its the switch but seems to me to be quite weird that it hasnt just failed altogether. (Maybe it will in a week!).
    Anyway, if anyone has had this issue before or can tell me which part I should be ordering to fix it, I would be very grateful.
    (Possibly relevant, but I dont see how, I installed a pid kit a few years ago).
    tek
    tek is offline
    Sep 2010
    141
    Re: Silvia - is my brew switch on the way out? If not, what is?
    Most likely a switch as you suggest
    KJM
    KJM is offline
    May 2007
    688
    When I got my Silvia, it came with a duff switch pre-installed...
    Chris sent me a replacement that has been good since I put it in. The original switch had the plastic doofer in the middle cracked (inside the switch). This meant that like you, I had to turn off,on,off,on... to get it to go. It is a simple over-centre type mechanism. You can get them apart with a couple of small jewellers screwdrivers, but once you have it apart you kind-of get stuck..
    The short answer is you need to get a new switch. They have, as they say, no user serviceable parts inside. They remind me of 1970s Italian motorcycle electrics ;D
    /Kevin
  1. Silvia - Fast Brew Cycle
    By dnolsen77 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 26th March 2013, 07:52 PM
  2. Heavily modded Silvia - brew issues
    By gab9479 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 5th March 2013, 03:59 PM
  3. Silvia - Problems after brew head clean!
    By tony8028 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 1st March 2013, 03:35 PM
  4. Rancilio Silvia - steam switch ON whilst brewing?
    By Toad in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 11th January 2011, 01:27 PM
  5. Silvia Brew Pressure problem?
    By beanmeupScotty in forum Brewing Equipment (non-machine specific)
    Last Post: 20th June 2006, 09:20 AM
