Results 1 to 6 of 6
Thread: Self catering for my coffee needs which makes a better coffee Sunbeam 6910 or Presso
    Jan 2011
    11
    Hello All
    I have recently moved to the suburbs and am struggling to find a coffee to my standards.
    I drink a Piccolo or Macchiato, I will be using the machine a few time during the week and weekends where I have an average of two coffees a day
    Questions
    I am trying to decide how I am going to self cater for my coffee needs.
    * I already have a grinder Delonghi KG100 do I need to upgrade my grinder
    * With the style of coffee I drink I am not sure whether the sunbeam 6910 is an overkill as i am happy to microwave the milk.
    *Presso Coffee maker..from what I have read the Presso makes a good coffee
    *So Finally I need help Sunbeam 6910 or Presso
    ***Please help because i am confused on what to purchase
    Jun 2008
    1,520
    Re: Self catering for my coffee needs which makes a better coffee Sunbeam 6910 or Presso
    i noticed the grinder deal is on again with the 6910, i was thinking you will need to upgrade our kg100 for both the presso or 6910
    6910 gives you easier range of coffees Presso might be simpler and cheaper
    Aug 2010
    204
    Considering the KG100 only has ten grind settings... Id go with the presso - you can change the pressure to vary your extraction.
    If you want to use a pump driven machine Id get a grinder which has more adjustment levels.
    Jan 2011
    11
    I am appreciating the feed back, I have just discovered the Lelit Combp is this another option I should consider???
    Jun 2008
    1,520
    Quote Originally Posted by 61494A4243487964544351260 link=1294219198/3#3 date=1294220403
    yes its about the same level as a Gee, 6910, silvia etc
    it (lelit) is a single boiler so you need to understand the difference to thermoblock machines and how they operate
    Senior Member shapeshifter's Avatar
    Oct 2010
    Newcastle
    726
    Just to add another comment for people that many consider the manual way over a cheaper machine, my opinion is that the manual way is better.
    We picked up a give away machine from the pay it forward board and are really glad we did, *Its a Breville and was worth Ive seen around $450, my OH pulled it apart, we cleaned it all up and then put it back together and tested it.
    Of course we couldnt just not use it :), I like trying out how coffee tastes from different machines so we started using it.
    I then switched back to the Presso and I can tell you the coffee is sooooo much better, its cleaner and you can actually taste the flavours in the coffee, with the Breville sure you could tell it was a different coffee but not by much.
    I use the Breville for the steam wand for milk for my OHs coffees and occasionally mine and thats about it now.
    I thought I should add that this opinion only stands for the cheaper end of the machines, I havent used any of the top end mahcines yet to see if my thoughts still stand.
  1. Gee machine or the lelit combo - Continued from Self catering for coffee needs
    By Golden_Brew in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 6th January 2011, 05:41 PM
  2. My first Coffee Catering Event - Success!
    By WSullivan in forum General Coffee Related...
    Last Post: 14th March 2010, 09:44 PM
  3. Coffee Newbie - Sunbeam 6910
    By wanted in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 10th November 2009, 12:13 AM
  4. New Sunbeam 6910, Cant make a cup of coffee!
    By vonkad in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 27th May 2008, 09:13 AM
