My EM6910 is about 22 months old (so still under pump warranty).
It has started leaking water underneath - even if switched off the whole tank will drain onto the bench.
The tank itself seals well, if taken out of the machine.
Questions are:
- should I try to pull it apart to have a look for the problem; is there a chance Ill be able to source a part if I find something split/perished etc?
- are there dissassembly instructions accessible somewhere?
- if I can identify a part, is there a parts supplier I should use, or try SB directly?
- is it likely to be worth taking to a repairer?
Any advice appreciated!
Michael
