Results 1 to 5 of 5
Thread: Does the Silvia steam valve need lubrication?
    Arv
    Arv is offline
    Apr 2008
    4
    Thanks to the excellent people at coffeeparts.com, Ive just performed my first proper service on my pre-08 Silvia, triggered by coming home from 2-weeks away to find my group head seal hosed; possibly from not being used during that time? I took the opportunity to pull apart some of the more important bits and clean them out and replace gaskets and o-rings.
    It works great now, I should have done this long ago and will be sure to make a more regular habit of it. However, the steam valve is now slightly stiffer to turn, especially for a particular part of the turn (i.e. each 360 degree turn involves a stiff portion and a more free-moving portion), plus its a tad squeaky when turning it. Im just assuming this is OK and will smooth out after a little while however Im wondering if I should be lubricating the thread of the inside of the steam valve with something? Itd be lovely with a bit of oil but I imagine that would work its way into the steam. Is there a correct procedure for this?
    Arv
    tek
    tek is offline
    Sep 2010
    141
    Re: Does the Silvia steam valve need lubrication?
    Use a food grade grease metal on metal means wear it should be lubricated
    Arv
    Arv is offline
    Apr 2008
    4
    Thanks for the response.
    Is that something I can just pick up at a hardware store or do I need to go somewhere special (or online perhaps?).
    Arv
    Arv is offline
    Apr 2008
    4
    Ahh, never mind, found a relevant thread.
    Arv
    Arv is offline
    Apr 2008
    4
    All done, I couldnt source any food-grade grease locally so I got it from Di Bartoli online. Machine feels fantastic, its like new; except for the exterior which is notoriously difficult to keep nice, plus the stupid laminated plastic bit surrounding the group head.
    Anyone out there with a Silvia thats been more than a couple of years without a service, performed professionally or otherwise, I would highly recommend it.
  1. Silvia steam valve issue maybe?
    By Sarg in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 10th November 2011, 03:39 PM
  2. sticky Silvia steam valve
    By philipmach in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 18th January 2009, 11:00 AM
  3. Squeaky Silvia steam valve
    By LastMile in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 29th September 2008, 08:23 AM
  4. Silvia steam valve squealing?
    By gregpullman in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 13th June 2007, 02:30 PM
