Results 1 to 2 of 2
Thread: Gaggia Classic power switch
    Jan 2011
    11
    Hi Guys,
    Ive only had my Classic for about 2 weeks, and it appears the light on the power switch is busted. the light on the brew switch is still working. Does anyone have any idea what the problem could be? Is there a loose wire or would I need to replace the switch? Thanks!
    Jer.
    Oct 2010
    483
    Re: Gaggia Classic power switch
    You would almost certainly need to replace the switch, as they are not designed to be disassembled.
    As long as you still have the brew switch light, you should be able to continue using it - you can tell if it is on or off by the switch position.
    If you do want a new switch, try here
    http://www.unpaid.com.au/product/Gaggia_Classic_On-Off_Switch
    Bear in mind that it is 240V and any work should only be carried out by a registered sparky.
  1. Gaggia Classic steam losing power
    By patanab in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 27th March 2016, 11:28 PM
  2. Gaggia Classic Switch Assembly
    By Degrees in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 26th December 2013, 01:58 AM
  3. How to power up a PID in Gaggia Classic
    By Sindibad in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 9th November 2013, 02:38 PM
  4. Power switch
    By Gra in forum General Coffee Related...
    Last Post: 27th December 2009, 05:38 PM
  5. Gaggia Classic - tripping safty switch
    By BamBam in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 11th April 2009, 08:47 PM
