Results 1 to 4 of 4
Thread: Rancillio Silvia question - hot water ?
    Feb 2011
    1
    Hi there, I am considering buying a Silvia however my wife is insisting I buy a machine with a dedicated hot water spout such as the breville we have now for those long blacks. Does the Silvia have a hot water function via the steam wand? Is there any alternative argument I can use to persuade her in in terms of having this machine deliver sufficient hot water? The topic does not seem to be discussed much in forums etc. and yes I do realize she can just boil the kettle...... :)
    thanks
    Site Sponsor
    May 2008
    Frenchs Forest NSW
    786
    Re: Rancillio Silvia question - hot water ?
    Quote Originally Posted by 7F787C737478427674791D0 link=1298895028/0#0 date=1298895028
    Yes.
    Nov 2010
    20
    Button in the middle of the group of three turns on the pump and directs hot water to the steam wand. First spurt of hot water on turning on the steam tap is at high pressure and can splatter. After that there is a good controllable flow. Used if for many years for long blacks.
    Nov 2007
    BRISBANE
    201
    Hi beanie kid and welcome to Coffee Snobs.
    I have used my Silvia for a few years now and make a good proportion of long blacks. The way I was taught to make long blacks was to partially fill the cup with hot water and then pull the double shot into the cup so that you end up with all the lovely crema on top. If you do this using the hot water function on Silvia, the water temperature in the boiler is taken too low for pulling a great shot. I always boil the kettle for hot water for long blacks and to heat the cups for caps or flat whites.
    The hot water function is great on commercial machines and high end prosumer machines but not so great on single boiler machines with small boilers.
    Alan
  1. Rancillio L6 cannot see water level in sight glass
    By rider in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 30th August 2012, 08:13 PM
  2. !!!SOLD!!! FS Rancillio Silvia V3
    By Ausnadian in forum SOLD
    Last Post: 6th July 2012, 01:20 PM
  3. Question about drawing water now that I have replaced the in tank water softner
    By barrel in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 24th August 2009, 09:43 PM
  4. Water leaking in Rancillio Silvia
    By jazzy_boy in forum Brewing Equipment (non-machine specific)
    Last Post: 27th December 2006, 08:40 PM
