Results 1 to 7 of 7
Thread: Silvia Problems
    Mar 2011
    10
    Silvia Problems
    Being relatively new to the real coffee scene, about 4 months ago purchased a used silvia. Being working great until today. After a couple of shots lost pressure coming out of the brew head, but is still good using the water function. Is this fixable at home or is it a service centre job? Any help would be greatly appriciated.
    Aug 2004
    2,312
    Re: Silvia Problems
    Welcome to CS.
    Sounds like a service centre repair.
    Regardz,
    Attilio
    very first Cs site sponsor.
    Mar 2006
    703
    Re: Silvia Problems
    When was the last time you took the shower screen out and cleaned it?* If not done regularly it can slowly block up till you lose pressure through the group-head.* If so, this can easily be fixed at home, by removing shower screen and giving it a good soak in espresso machine cleaner, and then remove the gunk with a brush.
    Another possibility, the three way valve is sticking open, you would see water flowing into back of drip tray while trying to pour shot, this may also be fixed at home IF you are confident to follow guides posted on the net, but may be better done by service centre.
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: Silvia Problems
    Quote Originally Posted by 7B747B7274242C2227150 link=1301376140/0#0 date=1301376140
    Your NEW and If bought second hand and you have not already done a Chemical clean at time of bringing home....
    It suggests to me that YOU need some training etc.
    Find the nearest sponsor / service provider for the machine and book in for a service and user training.
    Otherwise you will be disinterested / disappointed* and the machine will end up broken.
    Mar 2011
    10
    Re: Silvia Problems
    Thank you for your comments, since I have had the machine I have been descaling , backflushing and keeping it clean. After work I wondered down to coffee craft , which is only 5 mins away and they seemed to think it is a blockage of some sort and to bring it in for a looksy.
    Aug 2004
    2,312
    Re: Silvia Problems
    Hello nanga,
    partially blocked showers (even almost completely blocked ones) do not in my experience exhibit the kind of symptom you describe and we wouldnt want to encourage you to electro-kill yourself getting into places where you really should-na! ;)
    So, glad you decided to take it to a service centre. :)
    Rgdz,
    Attilio.
    Mar 2011
    10
    Re: Silvia Problems Update
    Took the machine to Coffee Craft in Glandore for a service .Dropped it off at 930 and was done by 1100. the problem was the undercup seal had perished and blocked the jet. Said seal ,and a couple of others were replaced, and presto working again. thay also gave the machine a general service. Total cost was about $100.
  1. Silvia first day problems
    By RJM in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 26th June 2011, 07:11 AM
  2. Silvia with PID and Compak K3 - problems dialing it in
    By SimonC in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 27th December 2010, 08:59 AM
  3. Newbie - Silvia Coffee Problems
    By marxman in forum Brewing Equipment (non-machine specific)
    Last Post: 22nd September 2006, 07:52 AM
  4. Silvia Problems
    By JR in forum Brewing Equipment (non-machine specific)
    Last Post: 18th January 2005, 08:16 AM
