Results 1 to 6 of 6
Thread: EM6910 - filter jug in place of calc filter?
    Oct 2010
    9
    I dont really want to buy $30 filters from sunbeam, so Im wondering if I just used a brita style filter jug will this remove the need for the anti calc filters (in conjunction with regular decalcing)?
    Caffeine Junky
    May 2009
    1,103
    Re: EM6910 - filter jug in place of calc filter?
    The use of Brita filters has been discussed on a number occassions, you can try a search using the function at the top of the page.
    Essentially the Brita filters have a pretty limited capacity to remove calcium and other scale causing chemicals.* Depending on the amount of ions in your tap/source water this capacity could be lost after only a few litres.* If you live in Melbourne which generally has very soft water, it may be fine.
    The Sunbeam filters can be recharged, again you can search for the method to do this.
    I have filtration system connected to my kitchen sink. After the filters are around 3 months old I tend to check the water with hardness test strips which are quite cheap, especially if bought in bulk. I guess in theory you could test the water coming out of the group on your Sunbeam for hardess.
    Oct 2010
    9
    Thanks, Ill steer clear of a filter jug then.
    I did do a search but I must have been using the wrong terms...
    I also did a search re recharging the filter but cant find overly specific information...
    I did find one post that said to soak it for 4-8 hours in "salty" water - how much salt?
    Is a filter infinitely rechargeable - or is this something that can only be done a few times with decreasing efficacy?
    Caffeine Junky
    May 2009
    1,103
    From what I remember a couple of tablespoons in a tall galss.
    No idea how many times they can be recharged, I would imagine thered be a limited number of times.
    Eventually they go a dirty yellow colour, Id imagine you want to recharge before they go like that, not 6 months after theyve turned yellow.
    A simple & accurate way to check would be with water hardness test strips. Many sponsors sell them but you could also probably get them from any pool supply store.
    Oct 2010
    9
    Thanks mate, I think I might have some strips lying around actually, Ill do some experimenting...
    Senior Member Rusty's Avatar
    Apr 2004
    Carlingford NSW
    691
    Replacing the filter is just a normal part of the cost of enjoying great coffee. $30pa is no big deal :o
  1. Recharge EM6910 Anti-Calc Filter
    By CafeSinLeche in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 10th July 2013, 04:11 PM
  2. Calc filter salt treatment
    By coffee_hombre in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 18th June 2010, 04:03 PM
  3. paper filter in bottom of espresso filter basket
    By stuartgrant in forum Brewing Equipment (non-machine specific)
    Last Post: 7th August 2008, 11:49 AM
